Salve, hp eseguito da poco l'aggiornamento firm sul 119pro alla 3.4.2, ho notato che anche dopo aver terminato il download di alcuni file torrent tramite la downlad station la spia del traffico di rete lampeggia con una velocità impressionante, cosa che non accadeva con il firm. precedente. Decido di verificare il traffico col registro del router inserendo una regola che logga tutto il traffico, e questa è una piccolissima parte del log:
Sat, 2011-04-23 19:14:46 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:207.134.201.225,6881 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:46 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:173.219.185.3,41331 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:47 - TCP Packet - Source:xxx.xxx.xxx.xxx,47980 Destination:95.215.62.26,80 - [Any(TCP) rule not match]
Sat, 2011-04-23 19:14:49 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:119.159.15.226,11228 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:50 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:92.37.25.113,24754 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:50 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:189.122.48.187,40869 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:50 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:92.46.151.162,57992 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:50 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:80.56.163.216,59036 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:50 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:192.11.19.1,13528 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:51 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:173.75.146.13,41626 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:14:59 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:109.205.252.59,51584 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:00 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:81.203.178.226,25454 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:01 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:78.101.5.40,23861 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:74.79.218.8,56937 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:184.82.184.149,6821 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:218.171.53.159,13198 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:77.106.88.198,43548 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:89.35.239.13,38832 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:89.222.246.6,6881 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:95.133.100.111,10452 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:71.198.61.187,30147 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:46.73.96.174,52325 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:84.20.133.135,6881 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:82.231.28.61,51413 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:173.181.109.4,60538 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:06 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:112.105.100.3,16001 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:07 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:41.227.199.249,34866 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:07 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:112.105.100.3,16001 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:08 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:58.103.171.18,24510 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:08 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:81.200.54.200,3048 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:10 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:62.21.53.38,7641 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:10 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:210.6.104.2,15723 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:10 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:94.229.60.130,55615 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:10 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:80.56.163.216,59006 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:11 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:119.159.15.226,11934 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:11 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:89.178.90.69,18903 - [Any(UDP) rule not match]
Sat, 2011-04-23 19:15:11 - UDP Packet - Source:xxx.xxx.xxx.xxx,6881 Destination:90.45.241.215,58634 - [Any(UDP) rule not match]
Ora mi chiedo, perchè a download terminati, il qnap va a cercare tutti questi indirizzi ip generando un traffico mostruoso??? Dimenticavo, se disabilito la download station, tutto questo traffico non viene generato.
Se qualcuno ha qualche suggerimento, ringrazio in anticipo.
Traffico di rete eccessivo
Torna a “Download Station e QGet”
Vai a
- Generale
- ↳ Annunci importanti
- QNAP ergo sum!
- ↳ L'angolo delle vanità
- ↳ Wiki QNAP (aka QNAPedia)
- ↳ Guida Utente online
- ↳ QNAP Shop
- ↳ FAQ (Italiano)
- Firmware e QPKG
- ↳ Modelli fuori produzione
- ↳ [STABILE] NMP-1000P
- ↳ Pacchetti software QPKG
- ↳ MLDonkey / aMule
- ↳ phpMyAdmin
- ↳ Joomla!
- ↳ WordPress
- ↳ SABnzbd+
- ↳ AjaXplorer
- ↳ XDove
- ↳ Asterisk
- ↳ Icestation (BETA)
- ↳ rTorrent++ (BETA)
- ↳ GLPI
- ↳ NZBGet
- ↳ ownCloud
- ↳ HD Station
- ↳ TV Station
- ↳ Google Drive Sync
- ↳ HappyGet
- ↳ DJ Station
- ↳ Virtualization Station
- ↳ Notes Station
- ↳ Utility varie
- Discussioni specifiche
- ↳ QIoT Containers
- ↳ DDNS & Port Forwarding
- ↳ RAID
- ↳ Download Station e QGet
- ↳ Apple Mac OS
- ↳ Miscellanea
- ↳ QGenie
