QTS 5.1.0
lucam1970
QTS 5.1.0
Messaggio da lucam1970 »
E' uscita una nuova versione del QTS 5.1.0, precisamente la 5.1.0.2466 build 20230721 datata 25/07/2023.
Tanto per farci stare tranquilli, la precedente versione, ovvero la 5.1.0.2444 (che era stata anche la RC3), è sparita del tutto, almeno per quanto riguarda i miei modelli di NAS.
Di seguito potere trovare l'elenco completo delle novità apportate con l'ultima release.
[Important Notes]
- In QTS 5.0.1 or earlier, users can no longer create new VJBOD disks from a remote NAS if the remote NAS is running QTS 5.1.0 or later. If there are existing VJBOD disks connections to the remote NAS before it is updated to QTS 5.1.0 or later, these VJBOD disks are unaffected and remain operational after the update. In QTS 5.1.0 or later, users can still create VJBOD disks from a remote NAS running QTS 5.0.1 or earlier.
- To use QNAP cloud services, please ensure that your network environment can access our service endpoints. For details, see https://www.qnap.com/go/how-to/faq/con_ ... p?cid=2851
- Removed support for CO Video.
[New Features]
Control Panel
- Administrators can now delegate roles to non-administrators in Control Panel > Privilege > Delegated Administration. This feature allows non-administrators to perform routine tasks and manage system resources, thus greatly enhancing productivity and flexibility.
- Added support for Hailo-8 AI accelerator devices. Users can also configure Hailo-8 usage priorities for apps using Hailo-8 devices.
- Added the client umask feature to assigns default permissions for existing and new files and folders.
- Added the Qfinder discovery service that allows the Qfinder Pro utility to discover your QNAP device.
Desktop
- You can now log out of your account on all devices, browsers, and applications at once. To use this feature, go to the desktop, click your username on the taskbar, and then go to Login and Security > Password.
- Added an icon on the top-right corner of the desktop to indicate whether the device has enabled myQNAPcloud and been associated with a QNAP ID or whether the device has joined AMIZ Cloud.
File Station
- Enhanced the search function and search result interface. Users can now search file content with Qsirch.
- Added support for the Recent Files function. Users can now quickly browse recently uploaded/accessed/deleted files.
Help Center
- Redesigned the user interface of Help Center for a better user experience.
Initialization
- You can now purchase licenses during QuTScloud installation.
iSCSI & Fibre Channel
- Added support for enabling async IO for block-based LUNs, which can improve the performance of a LUN over an iSCSI connection particularly when the LUN contains dual-actuator HDDs. To find this setting, go to iSCSI & Fibre Channel > iSCSI Storage, select a block-based LUN, and click Action > Modify.
- Added a new settings page for managing default iSCSI CHAP authentication settings, which you can use for multiple iSCSI targets. You can find these settings in iSCSI & Fibre Channel > Global Settings > Default iSCSI CHAP. When creating or editing a target, you can choose to use the default CHAP settings or configure unique settings for the target.
myQNAPcloud
- You can now add the NAS to an organization when setting up myQNAPcloud. This allows organization administrators to centrally manage and monitor various system resources on NAS devices via AMIZ Cloud. (AMIZ Cloud Agent must be enabled in myQNAPcloud.)
Network & Virtual Switch
- Network & Virtual Switch can now record event logs when the system identifies conflicting IP addresses between the local device and another device on the same network.
- When selecting the system default gateway automatically, you can now configure the checking target by specifying the domain name or IP address.
- Users can now configure the MAC address when creating or modifying a virtual switch.
NFS
- Users can now set the rcpbind to assign fixed ports to RPC services. Make sure that you configure the firewall rules accordingly to allow connections only on the fixed ports.
SAMBA
- Microsoft networking now supports SMB multichannel settings, which allows file servers to use multiple network connections simultaneously.
Storage&Snapshots
- Added a new window that automatically appears when you insert new disks and helps you decide what to do with them. You can also access this window any time by going to Storage & Snapshots > Storage > Disks/VJBOD > Disks > More > Manage Free Disks.
- Added support for enabling Native Command Queuing (NCQ), which improves the read and write performance of SATA disks.
- Added support for disk failure prediction from ULINK's DA Drive Analyzer. Registered users of DA Drive Analyzer can now also monitor disk failure prediction statuses in Storage & Snapshots > Storage > Disks/VJBOD > Disks.
- Added support for Western Digital Device Analytics (WDDA) for Western Digital (WD) disks. To view WDDA information, go to Storage & Snapshots > Storage > Disks/VJBOD > Disks, select a WD disk, and click Health > View Details.
System
- QTS now supports Passwordless Login, which replaces your password with a more secure verification method. QTS now also supports more verification methods for 2-Step Verification. To configure these settings, go to the desktop, click your username on the taskbar, and then select Login and Security.
- You can now scan the QR code of your NAS with a QNAP mobile app to easily add this NAS to your mobile app. This QR code contains essential network information for remote connection. To get this QR code, go to Desktop > More > Device QR Code.
[Enhancement]
App Center
- Users can now configure a schedule for automatic installations of app updates.
Control Panel
- You can now specify a custom unique identifier (UID) for a new user and edit the UID of an existing user. Note: Arbitrarily changing UIDs may cause access issues for a user.
- The time interval for observing successive failed login attempts can now be configured to be between 0 and 600 minutes. Moreover, a time interval of 0 minutes means that failed login attempts are never reset.
- Changed the behavior and the description of certain permission settings as we do not recommend using the default administrator account "admin".
- You can now include more information from account profiles when importing and exporting user accounts.
- Added additional specification information for memory slots in Control Panel > System Status > Hardware Information.
- You can now select the direction to append the custom header for the reverse proxy rule.
- Optimized the process of restoring the LDAP database.
- The automatic firmware update settings have been streamlined with the following changes:
*The selectable options for automatic firmware updates have been greatly simplified. Users now select one of three firmware types to automatically update their system with: quality updates, critical updates, or latest updates.
*"Security updates" are now "critical updates". Critical updates include security fixes as well as critical system issue fixes.
*"Quality updates" now include security fixes and critical issue fixes in addition to bug fixes.
*"Feature updates" are now "latest updates" and include quality and critical updates in addition to new features, enhancements, and bug fixes.
* Update notifications no longer need to be enabled separately for each firmware type. Notifications are now either enabled or disabled for all firmware types.
- You can now edit, enable, and disable power schedules.
File Station
- Added prompt banners to remind users to turn on related browsing functions for multimedia files.
- Improved File Station performance and enhanced file browsing experience.
- Enhanced the Background Tasks display UI.
- When creating an iSCSI target, you can now select the network interfaces that an iSCSI target will use for data transmission. Previously, users could only do so after the target was created.
Login
- Users can now save their QTS login credentials in their web browser. To enhance the security of your QTS user account, we recommend enabling 2-step verification.
NFS
- NFS service now supports both NFSv4 and NFSv4.1 protocols.
PHP System Module
- Updated the built-in PHP version to 8.2.0.
Resource Monitor
- Resource Monitor now displays the space used by files created from Qsync file versioning.
SAMBA
- The SMB protocol now supports the AES GMAC 128-bit key encryption.
- You can now aggregate up to 50 shared folders on a Windows network.
- Updated Samba to version 4.15.
- The kernel-mode SMB daemon is now enabled by default.
Storage&Snapshots
- Expanded and improved the "Activate Predictive S.M.A.R.T. Migration" feature and renamed it "Predictive Migration". Previously, this feature automatically migrated data from a faulty disk to a spare disk when S.M.A.R.T. errors were detected on the faulty disk. Now, users can specify various trigger events from sources other than S.M.A.R.T., including Western Digital Device Analytics, IronWolf Health Management, DA Drive Analyzer, and SSD estimated life remaining. You can configure this feature in Storage & Snapshots > Global Settings > Disk / Device.
- When adding a remote disk, more information is now provided on each LUN in the LUN list to help users identify which one to select.
- After rebuilding a RAID group with a spare disk, the failed disk's slot becomes reserved for a spare disk. To free up this slot for other purposes, go to Storage & Snapshots > Storage > Disks/VJBOD > Disks, select the disk slot, and click Action > Free Up Spare Disk Slot.
- You can now select and configure multiple spare disks when creating a storage pool.
- Redesigned the presentation of disk information into tabular format for enhanced user experience, now viewable in Storage & Snapshots > Storage > Disks/VJBOD > Disks.
- Users can now see disk error logs in QuLog Center.
- Redesigned the presentation of NAS and enclosure information into tabular format for enhanced user experience, now viewable in Storage & Snapshots > Storage > Disks/VJBOD > NAS & Enclosure.
- Qtier now supports more flexible tier configurations with NVMe and SATA SSDs.
- In Storage & Snapshots > Storage > Disks/VJBOD > Disks, information on each disk's slot number, form factor, interface, and disk type are now presented together and enhanced with colored tags so that users can more easily identify each unique disk and disk slot.
- Updated the UI design of various snapshot-related screens to improve user experience in finding relevant information and functions.
- Added support for 2-step verification when connecting to a remote NAS in the Create Virtual JBOD Disk Wizard.
- Renamed the function "Replace & Detach" to "Replace" and added the option for users to choose whether to designate the replaced disk as a spare disk or to detach it from the system.
- After creating a SED secure static volume or SED secure storage pool, the encryption key file is now automatically downloaded to help users unlock the volume or pool in case they forget the encryption password.
- Improved SED-related UI strings for clarity.
- Users can now change the destination of an existing Snapshot Replica job.
- Enhanced the UI for snapshot deletion to provide more information for snapshot statuses and background tasks.
- Added the new IronWolf Health Management (IHM) status "Critical Warning" for Seagate drives. The new IHM status replaces "Not Available" as a trigger event in Predictive Migration. QTS also no longer blocks a Seagate drive when the drive's warranty status cannot be obtained from Seagate servers.
System
- You now need to enter a verification code when resetting your password if you forgot your password. This extra step helps enhance your account security.
[Fixed Issues]
- Resolved an issue where after upgrading their NAS to QTS 5.1.0, users could not map a LUN originally created in earlier versions of QTS released in or before 2019.
- Fixed an issue where users could not join a Windows device to the NAS domain controller after updating Windows 10 to KB5028166.
- Fixed an issue in QTS 5.1.0.2418 and 5.1.0.2444 that caused iSCSI & Fibre Channel to stop responding after trying to open the application.
[Known Issues]
- QTS with newer kernel versions do not support ATTO Fibre Channel adapters. If you have already installed an ATTO Fibre Channel adapter on your device, we do not recommend updating the firmware to QTS 5.1.0 for the time being.
[Other Changes]
Control Panel
- Moved DLNA Media Server settings from Control Panel to Multimedia Streaming Add-on, which can be installed in the App Center.
- The "Network Recycle Bin" feature has been renamed to "Recycle Bin" in Network & File Services.
Batman
Re: QTS 5.1.0
Messaggio da Batman »
Quest'ultimo aggiornamento sta diventando FASTIDIOSO!!!
Ogni cosa fai sul FileStation 5 si apre la finestra delle Attività in background e non c'è modo di impedirlo.
In oltre se trascino (Drag and drop) un qualsiasi file multimediale (foto o video) dal desktop del computer ad una cartella del NAS, questa viene bloccata immediatamente con un messaggio che mi avverte che devo installare l'App Multimedia Console ...PERCHE ?????
lucam1970
Re: QTS 5.1.0
Batman ha scritto: 27 lug 2023, 23:13 Ogni cosa fai sul FileStation 5 si apre la finestra delle Attività in background e non c'è modo di impedirlo.
potrebbe trattarsi di questa nuova funzione sui "Recent Files" che è riportata nell'elenco delle novità?
Prova a vedere se c'è qualche impostazione al riguardo e soprattutto se può essere disabilitata ...
Io pensavo di installare questa versione sul NAS di backup per sperimentare un po'.
Ho ancora qualche ora per pensarci su perchè sto facendo una espansione volume .....
Batman
Re: QTS 5.1.0
lucam1970 ha scritto: 28 lug 2023, 00:00 Prova a vedere se c'è qualche impostazione al riguardo e soprattutto se può essere disabilitata ...
Ho cercato ovunque e non l'ho trovata.
Aggiungo altre cosine seccanti:
Nella home in alto a Dx c'è l'icona che invita ad attivare un servizio cloud ...non mi interessa!!!
Sempre nella barra, una notifica che ti avvisa di inserire un modo per recapitare le notifiche stesse ...non mi serve!!!
Al momento utilizzo il NAS come semplice storage domestico più server PLEX, per cui ben vengano nuove funzioni ma basta con avvisi e complicanze varie
Re: QTS 5.1.0
Adesso è obbligatoria la regola per notificare i nuovi firmware, regola che avevo già.
Se non si utilizza la loro regola, c'è sempre la notifica sulla destra dopo il login.
Idem per l'icona in alto a destra di myqnapcloud, la preferivo in un altra posizione.
Le altre cose segnalate, per adesso non le ho notate, visto il poco utilizzo di questo periodo.
lucam1970
Re: QTS 5.1.0
Ho installato quest’ultima versione sul nas di backup e, purtroppo, ho scovato un problema.
Non funziona più la programmazione accensione/spegnimento.
Il nas di backup deve accendersi la sera e spegnersi la mattina in modo da completare tutti i cicli di backup dal nas principale.
Farò qualche prova disabilitandola e riattivandola per vedere se si sblocca e poi eventualmente aggiornerò il thread.
Re: QTS 5.1.0
Ma non funziona più che senso ? Bug o altro
Perchè la funzione c'e ancora vedo
Io però non la uso
lucam1970
Re: QTS 5.1.0
n3rv0x ha scritto: 30 lug 2023, 12:12 Ma non funziona più che senso ? Bug o altro
Io però non la uso
Non funziona più nel senso che ieri sera non si è acceso e stamani l'ho trovato spento.
Sono andato a verificare sul panello di controllo e sia accensione che spegnimento risultavano disabilitate.
Ho provato ad abilitarle ma mi faceva attivare soltanto una delle due. O accensione o spegnimento.
Allora, ho cancellato tutta la programmazione e l'ho rifatta daccapo.
Stasera vedrò se parte.
Comunque la cosa che mi sta facendo davvero innervosire è che non si può disabilitare myqnapcloud.
Non si può interrompere, figuriamoci disinstallarla.
Se ne parla anche nel forum inglese.
Edit:
Dopo averla cancellata e reinserita ex novo, la programmazione dell'alimentazione funziona di nuovo
Batman
Re: QTS 5.1.0
Batman ha scritto: 28 lug 2023, 10:18Aggiungo altre cosine seccanti:
PiaNi ha scritto: 28 lug 2023, 11:56Adesso è obbligatoria la regola per notificare i nuovi firmware, regola che avevo già.
Trovata la soluzione: disabilitare la ricerca di aggiornamenti firmware e la notifica sparisce.
Ps: riguardo a tutti questi bug penso siano causati dai continui aggiornamenti ed implementazioni di nuove funzioni, forse (di tanto in tanto) sarebbe bene formattare ed installare da zero! : Sad :
Re: QTS 5.1.0
E' uscita la 5.1.1.2491.
Cioè siamo passati all 5.1.1
lucam1970
Re: QTS 5.1.0
Hai ragione ...
QTS 5.1.1.2491 build 20230815
Elenco lunghissimo di fix e non solo ...
[Important Notes]
- For details on new features in QTS 5.1, please visit https://www.qnap.com/go/release-notes/q ... 6/20230721
- To run Virtualization Station on QTS 5.1.1, version 3.6.49 or later is required. If you are using an earlier version of Virtualization Station, please update Virtualization Station before updating QTS to 5.1.1.
[Security Updates]
- Applied multiple security updates to further enhance system security.
[Enhancement]
- Optimized the switch configuration UI for QGD rackmount series running QTS, with added support for models that do not support PoE.
Control Panel
- System Status now displays the statuses of all power supply units on all external storage enclosures, regardless of whether the NAS supports redundant power supply.
Initialization
- Users can now configure firmware update settings in the Smart Installation Guide during QTS initialization.
Storage&Snapshots
- Upgraded the IronWolf Health Management (IHM) utility to implement support for the latest ST drive models as well as future models within the IHM-supported range.
- Upgraded the Western Digital Device Analytics (WDDA) utility to update the generated recommended actions.
[Fixed Issues]
- Fixed an issue where some users would encounter certain unexpected storage issues when reinserting a disk after a firmware update.
- Fixed an issue where some users would encounter disk partition issues on a JBOD enclosure after disconnecting and reconnecting the JBOD enclosure.
- Fixed an issue where mounting ISO files in File Station would trigger an "Unknown Error" message.
- Resolved an issue where the system sometimes could not create a snapshot due to insufficient metadata space.
- Fixed an issue where some files could not be recovered when recovering a folder with a large number of files from a recycle bin.
- Fixed an issue where some files could not be transferred when dragging and dropping a folder with a large number of files.
- Improved Thunderbolt compatibility between M1 macOS computers and QNAP NAS devices.
- Fixed an issue where if during shared folder creation the shared folder's path was entered manually, virus files that were later found in the shared folder and sent to quarantine would fail to appear in Control Panel > Applications > Antivirus > Quarantine.
- Resolved an issue where macOS devices could not access via Samba any shared folders that were created on a USB drive connected to the NAS.
- Fixed an issue where when the system default gateway had an IPv6 address and was connected to a virtual switch, the myQNAPcloud > DDNS page did not display the IPv6 address when My DDNS was enabled.
- Fixed an issue in HybridMount where users could not connect to a remote mount via Samba if the password contained certain special characters.
- Fixed an issue where when two users were simultaneously logged in to the same NAS and one user performed certain actions on a folder (either in File Station or via Samba from a remote client), the other user would encounter an unexpected error message when trying to access the same folder in File Station.
- Addressed an issue where after transferring a massive amount of data through a share link, users would experience reduced speeds when downloading through the share link later.
- Fixed an issue where creating a LUN in a volume-less storage pool would trigger a huge amount of repeated logs.
- Fixed an issue where users would encounter an erroneous authentication error message and fail to log in to a NAS using a domain user account via Samba.
- Resolved a rare issue in HybridMount where users might encounter the HTTP 414 error "Request-URI Too Long" when trying to create a mount connection to OneDrive for Business.
- Fixed an issue where users could not open Microsoft Office files in Office Online.
- Fixed an issue where if "Always keep SMB file attributes" was enabled in File Station > More > Settings > File Operations, and the user had uploaded a file to the NAS via SMB, copying the file to another folder in File Station would result in the file being stuck in "Preparing" status and the /tmp folder becoming full.
- Fixed a rare issue where Snapshot Replica jobs with a large amount of source data would fail to finish due to timeout.
- Fixed an issue where users could not configure a service to use a port number already reserved for another service even though the two services used different communication protocols (e.g., TCP and UDP).
- Fixed an issue where users could not access folders via Samba if their username contained certain special characters.
- Resolved an issue in HBS 3 where some users could not enable Time Machine service.
- Fixed an issue in File Station where if the NAS time is ahead of the client time, uploading a file would cause Background Tasks to incorrectly display a "Failed" message until the upload is complete.
- Improved MariaDB support for all time zones.
- Improved the display ratio of the desktop wallpaper.
- Improved the login process.
- Fixed an issue in File Station where folders would be incorrectly sorted if one or more of the folder names included certain special characters.
- Fixed an issue in File Station where if the NAS time was ahead of the client time, uploading a file would cause Background Tasks to incorrectly display a "Failed" message until the upload was complete.
- Fixed an issue in File Station where some action options were missing when right-clicking XLSM files.
- Fixed an issue where under certain circumstances, File Station would be stuck at "Searching..." after trying to search files by keyword.
- Fixed an issue where Notification Center could not send notification emails when notification rules were triggered.
- Resolved an issue where trying to add a QNAP ID that already existed in myQNAPcloud > Access Control > Custom Settings would incorrectly trigger an "Unknown error" message.
- Resolved an issue in Network & Virtual Switch where users would encounter an unexpected error when trying to add a static route using a VPN interface.
- Resolved an issue where iSCSI & Fibre Channel would stop responding for some users after trying to open the application.
- Fixed an issue in Notification Center where the system would continue to send email notifications to a recipient who had been removed from a notification rule.
- Resolved an issue where the system would incorrectly display an "Unable to send firmware update notifications" message after creating a notification rule for firmware updates.
- Fixed an issue in Qsirch where users could not search NAS files in Finder in macOS Ventura.
- Fixed an issue where users could not fully delete a shared folder if the shared folder contained a very large number of files.
- Resolved an issue where properly shutting down the NAS caused the S.M.A.R.T. attribute "Power-Off Retract Count" in HDDs to unexpectedly increase in value.
Re: QTS 5.1.0
Disponibile la 5.1.2.
lucam1970
Re: QTS 5.1.0
PiaNi ha scritto: 04 ott 2023, 10:21 Disponibile la 5.1.2.
Anche stavolta un riferimento generale, ma serio, alla risoluzione di problemi di sicurezza nonchè un lungo elenco di bug risolti a varie componenti/app del QTS, tra cui File Station e MyQnapCloud.
[Security Updates]
lucam1970
Re: QTS 5.1.0
Ho eseguito l'aggiornamento del nas di backup alla versione 5.1.2.2533 build 20230926.
Per il momento nulla di evidente da segnalare.
Se nei prossimi giorni noto qualcosa, aggiorno il thread.
Batman
Re: QTS 5.1.0
Batman ha scritto: 27 lug 2023, 23:13 Quest'ultimo aggiornamento sta diventando FASTIDIOSO!!!
Sembra che con l'ultimo aggiornamento ( 5.1.2.2533 ) il problema sia FINALMENTE sparito!
Alleluia : Rolleyes :
lucam1970
Re: QTS 5.1.0
Uscita nuova versione 5.1.3
Per la precisione 5.1.3.2578 build 20231110 del 15/11/2023
Da quello che si legge nelle note di rilascio, mi sembra un po' rischioso aggiornare a questa versione.
[Important Notes]
- This version is released in a staged rollout, which means we initially release this version to a small portion of users and then gradually reach more users over time.
[Security Updates]
[Enhancement]
Login
- Improved the web login speed for AD domain users.
Storage
- Optimized the RAID group resync speed for NVMe drives.
[Fixed Issues]
- Fixed an issue in File Station where users could not download files from "@Recently-Snapshot" folders.
- Resolved an issue in File Station where non-administrator users would see an empty list when trying to use the "Share to NAS user" function.
- Fixed an issue in HybridMount where subfolder permissions in a File Cloud Gateway mount sometimes changed after disabling and re-enabling the mount.
- After deleting a file in File Station, the Background Task window now no longer automatically opens so that users can quickly move on and perform other actions.
- Users can now successfully upload a folder that contains a very large number of files in File Station.
- Adjusting the bottom edge of a window now resizes the window again as expected.
- Resolved an issue on the TS-AI642 where running certain applications would sometimes trigger call trace logs.
- Improved system read/write speeds when SMB multichannel is enabled.
- Resolved an issue in Notification Center where some users still received notifications for events that they had excluded in a notification rule.
- The screen in Control Panel > Network & File Services > Network Access > Service Binding now correctly displays network interfaces that are in a port trunking group.
- Fixed an issue where after editing a file via Samba and then taking a snapshot, users could not access previous versions of the file.
- Users can now access a folder via WebDAV even when the folder name is very long.
- LDAP users can now successfully change their own passwords in Desktop > Task Bar > Options Menu > Login and Security.
- The TL-D800C JBOD enclosure now does not show errors in the PSU fan and PSU temperature fields in System Status. (Note: This model does not support displaying PSU fan or temperature statuses and thus should not show such errors.)
- In Control Panel > Privilege > Users, the Edit User Profile window now correctly displays password validity information after the user password has expired.
- Fixed an issue to improve the stability of system processes.
- Fixed an issue where after taking a snapshot of a volume, the "Storage Info" window (accessible by right-clicking a shared folder in File Station) would display incorrect information on some shared folders.
- Resolved an issue in File Station where the system would fail to send an email when users created a share link via email using a custom email service provider.
- The system now no longer creates multiple folders when a domain user creates a single folder via SMB.
- After creating a share link via email in File Station, line breaks in the "Message" field are now accurately preserved in the delivered email.
- Users can now successfully recover deleted folders containing large files from a "@Recycle" folder.
- Fixed an issue where QuLog Center could not send notifications after users added filter criteria in "Notification Settings" > "Send filtered results to Notification Center" > "Local NAS - Access Log".
- Windows users can now successfully delete NAS files via Samba even when the file names are very long.
- Resolved an issue where on a NAS that was configured as a domain controller, Group Policy Object (GPO) configurations would disappear each time the NAS restarted.
- Improved the shared folder permissions mechanism for domain users with delegated roles.
- Fixed an issue where SNMP requests would encounter timeout errors.
- Addressed an issue where users could not update NAS firmware to the latest version via AMIZ Cloud.
Re: QTS 5.1.0
Scrivono così:
[Important Notes]
ma poi è possibile scaricarlo liberamente.... : Blink :
lucam1970
Re: QTS 5.1.0
Al di là del controsenso è proprio in questa cosa del "rilascio graduale" che intravedo, personalmente, un rischio.
Già è abbastanza evidente che gli utenti fanno costantemente da beta tester....
Se poi precisano che non sarà rilasciato liberamente a tutti, vien da pensare che ci sia la preoccupazione che qualcosa non funzioni.
Magari c'è una spiegazione...
Re: QTS 5.1.0
Nessun problema con questa versione.
Re: QTS 5.1.0
C'è la versione QTS 5.1.4.2596 build 20231128.
