La sera terminato lo scrubbing ho spento il nas, ma stamattina è ripartito da solo lo scrubbing senza motivo
Ho controllato le impostazioni ma non è abilitato per partire automaticamente, non capisco cosa lo faccia attivare
anche nel crontab questa riga è asteriscata
Codice: Seleziona tutto
#0 23 * * * /sbin/storage_util --data_scrubbing raid_id=-1 >/dev/null 2>&1
Informazioni 2023-04-08 08:00:00 --- --- localhost Malware Remover General [Malware Remover] Started automatically updating the application.
Informazioni 2023-04-08 08:30:52 --- --- localhost myQNAPcloud myQNAPcloud Device [myQNAPcloud] Updated WAN IP address to "xx.xx.xx.xx".
Informazioni 2023-04-08 08:30:44 --- --- localhost Storage & Snapshots RAID Group [Storage & Snapshots] Started resyncing RAID group "1". Volume: DataVol1, Priority: Resync First.
Informazioni 2023-04-08 08:30:27 --- --- localhost Multimedia Console Service [Multimedia Console] Started Multimedia Services.
Informazioni 2023-04-08 08:29:27 --- --- localhost Network & Virtual Switch Infrastructure [Network & Virtual Switch] Set "Adapter 1" as system default gateway. "Adapter 1" connected to the internet after checking NCSI.
Informazioni 2023-04-08 08:29:27 --- --- localhost Network & Virtual Switch Infrastructure [Network & Virtual Switch] Set "Adapter 1" as the system default gateway.
Informazioni 2023-04-08 08:29:27 --- --- localhost Network & Virtual Switch --- [Network & Virtual Switch] Initialized Network & Virtual Switch.
Informazioni 2023-04-08 08:29:26 --- --- localhost Power NAS Power Status [Power] The system has started.
Avvertimento 2023-04-08 08:29:26 --- --- localhost Power NAS Power Status [Power] The system was not shutdown properly last time.
Informazioni 2023-04-08 08:29:26 --- --- localhost Storage & Snapshots RAID Group [Storage & Snapshots] Started resyncing RAID group "1". Priority: Resync First.
Informazioni 2023-04-08 08:13:39 --- --- localhost myQNAPcloud myQNAPcloud Device [myQNAPcloud] Updated WAN IP address to "xx.xx.xx.xx".
Informazioni 2023-04-08 08:00:01 --- --- localhost Malware Remover General [Malware Remover] Finished automatic update check. No new software version found.
