QTS 5.0.1 beta pubblica
E' uscita la versione 5.0.1 per il momento è in versione beta, se non siete in grado di gestirla non ci mettete le mani.
QTS 5.0.1.2034 build 20220515 Beta pubblica
[Modelli applicabili]
- HS-251+, S2
- QMiroPlus-201W
- Mustang-200, Mustang-F100, Mustang-V100, Mustang-200-i7-1T-32G-R10, Mustang- 200-i5-1T-32G-R10, Mustang-200-C-8G-R10
- QGD-1600P, QGD-1600Pv0
- QGD-1602P
- QGD-3014-16PT
- TS-453S Pro, TS-853S Pro
- TS- 531P
- TS-128A,TS-228A,TS-212P3,TS-130,D1 Rev-B
- TS-231P3,TS-431P3
- TS-231P2,TS-431P2
- TS-831X,TS-531X,TS-831X v2,TS-431X,TS-431X2,TS-431X3,TS-431KX
- TS-431XU,TS-831XU,TS-1231XU,TS-431XU-RP,TS-831XU-RP,TS-1231XU-RP,TS- 431XeU
-TS-932X,TS-832X,TS-332X,TS-532X,TS-932PX,TS-832PX
-TS-432XU-RP,TS-432XU,TS-832XU-RP,TS-832XU,TS-1232XU-RP,TS-1232XU,TS-432PXU,TS-432PXU-RP,TS-832PXU,TS-832PXU-RP ,TS-1232PXU,TS-1232PXU-RP
- TS-133,TS-233,TS-433
- TS-1635
- TS-1635AX
- TS-231+,TS-431+,TS-131P,TS-231P,TS -431P,TS-131K,TS-231K,TS-431K,D2,D4,D4 Rev-B
- TS-251,TS-451,TS-651,TS-851,TS-451S,TS-251+,TS -451+,TS-351,D2 Pro Rev-B,D4 Pro Rev-B
- TS-251A,TS-451A,D2 Pro,D4 Pro
- TS-251B
- TS-451DeU,TS-453DU,TS-453DU- RP,TS-853DU,TS-853DU-RP,TS-1253DU,TS-1253DU-RP
- TS-451U
- TS-253 Pro,TS-453 Pro,TS-653 Pro,TS-853 Pro,TS-453mini, IS-453S
-TS-453Bmini,TS-253B,TS-453B,TS-653B,TS-253Be,TS-453Be
-TS-853BU,TS-853BU-RP,TS-1253BU,TS-1253BU-RP,TS- 453BU,TS-453BU-RP
- HS-453DX, TBS-453DX, TS-251D, TS-253D, TS-653D, TS-453D, TS-451D, TS-453Dmini, TS-451D2
- TBS-453A, TS-253A, TS-453A, TS -653A,TS-853A,D6 Pro,D8 Pro
-TS-453U,TS-853U,TS-1253U,TS-453U-RP,TS-853U-RP,TS-1253U-RP,R4
-TVS-463,TVS -663,TVS-863,TVS-863+,TS-563,TS-963X,TS-963N
- TS-463U,TS-463U-RP,TS-863U,TS-863U-RP,TS-1263U,TS- 1263U-RP,TS-463XU,TS-463XU-RP,TS-863XU,TS-863XU-RP,TS-1263XU,TS-1263XU-RP
- TS-564,HS-264,TBS-464,TS-262C, TS-462C, TS-262, TS-462, TS-264C, TS-464C, TS-364, TS-264, TS-464, TS-664
- TS-464U, TS-464U-RP, TS-1264U- RP,TS-464eU,TS-864eU,TS-864eU-RP
- TVS-471,TVS-671,TVS-871
- TVS-871U-RP,TVS-1271U-RP,TVS-471U-RP,TVS-471U, R8
- TVS-672N,TVS-872N,TVS-872X,TVS-672X,TVS-472X
-TVS-872XU,TVS-872XU-RP,TVS-1272XU-RP,TVS-1672XU-RP,TVS-2472XU-RP,TVS-972XU,TVS-972XU-RP
- TVS-473,TVS-673,TVS-873 ,TVS-473e,TVS-673e,TVS-873e
- TS-h973AX,TS-473A,TS-673A,TS-873A
- TS-873AU,TS-873AU-RP,TS-1273AU-RP,TS-1673AU-RP ,TS-873AeU,TS-873AeU-RP
- TS-873U,TS-1273U,TS-1673U,TS-873U-RP,TS-1273U-RP,TS-1673U-RP
- TVS-675
- TVS-h875U,TVS -h875U-RP,TVS-h1275U-RP,TVS-h1675U-RP
- TS-1277,TS-877,TS-677,TS-1677X
- TS-877XU,TS-1277XU,TS-1677XU,TS-877XU-RP ,TS-1277XU-RP,TS-1677XU-RP,TS-2477XU-RP,TS-977XU-RP,TS-977XU,TS-h1277XU-RP,TS-h977XU-RP,TS-h1677XU-RP,TS-h2477XU -RP
-TS-EC880 Pro,TS-EC1080 Pro,TVS-EC880,TVS-EC1080,TVS-EC1080+
-TS-EC880U,TS-EC1280U,TS-EC1680U,TS-EC2480U R2,TVS-EC1280U-SAS-RP R2,TVS-EC1580MU-SAS-RP R2,TVS-EC1680U-SAS-RP R2,TVS-EC2480U-SAS -RP R2,TS-EC2480U,TS-EC880U R2,TS-EC1280U R2,TS-EC1680U R2,TVS-EC1280U-SAS-RP,TVS-EC1580MU-SAS-RP,TVS-EC1680U-SAS-RP,TVS-EC2480U -SAS-RP,R12,R16,R24
- TVS-682,TVS-882,TVS-1282,TVS-882BR
- TVS-1582TU
- TS-883XU,TS-883XU-RP,TS-1283XU-RP,TS-1683XU -RP,TS-983XU,TS-983XU-RP,TS-2483XU-RP,TS-h1283XU-RP,TS-h2483XU-RP,TS-h1683XU-RP
- TS-1685,TS-h886,TS-h686
- TES -3085U,TES-1885U,TS-1886XU-RP,TS-h1886XU-RP,TS-1886XU-RP R2,TS-h1886XU-RP R2
- TS-2088XU,TS-h3088XU-RP
- TDS-16489U
- TS-h2490FU
- TS-328, TS-428, TS-230, D2 Rev-B
- TS-551
- TS-473, TS-673, TS-873
- TVS-951X,TVS-951N
- GM-1000,TNS-h1083X,TNS-h1083X (lato A),TNS-h1083X (lato B),TNS-h1083X (lato A),TNS-h1083X (lato B)
- TS -216,TS-416
- TS-435XeU
- TVS-882ST,TVS-882ST3
- TS-2888X,TVS-h1688X,TVS-h1288X
[Note importanti]
- QTS 5.0.1 pronto all'uso installa automaticamente gli aggiornamenti di sicurezza per impostazione predefinita. Tuttavia, se si aggiorna il firmware da QTS 5.0.0 a 5.0.1, QTS manterrà le impostazioni di aggiornamento del firmware esistenti. Ti consigliamo di controllare le impostazioni di aggiornamento del firmware in Pannello di controllo > Aggiornamento firmware.
- Rimosso il supporto per i seguenti strumenti per sviluppatori: Python 2, Node.js v4, Node.js v6, Node.js v8 e Ruby on Rails.
- Rimosso il supporto per le seguenti app o strumenti: Mono, Perl e AlarmClock. Ti consigliamo di eseguire queste app o strumenti utilizzando Container Station, se necessario.
[Aggiornamenti di sicurezza]
- Risolto il problema di sicurezza CVE-2022-0778. Per i dettagli, vedere https://www.qnap.com/en/security-advisory/qsa-22-06
- Risolti più problemi di sicurezza (CVE-2021-31439, CVE-2022-23121, CVE-2022-23123, CVE -2022-23122, CVE-2022-23125, CVE-2022-23124 e CVE-2022-0194). Per i dettagli, vedere https://www.qnap.com/en/security-advisory/qsa-22-12
- Sono stati applicati più aggiornamenti di sicurezza per migliorare ulteriormente la sicurezza del sistema.
[Nuove funzionalità]
Pannello di
controllo - Il pannello di controllo ora mostra le velocità di clock massime del processore.
- Il servizio NFS ora può supportare le porte statiche.
- QTS ora supporta le impostazioni di protezione dell'accesso per i protocolli RTRR e Rsync in Pannello di controllo > Sistema > Sicurezza.
- Gli amministratori ora possono imporre la verifica in due passaggi a utenti o gruppi specifici e quindi verificare il loro stato di verifica corrente. Dopo questa imposizione, gli utenti selezionati devono completare la configurazione della verifica in due passaggi prima di procedere con altre operazioni.
Desktop e accesso
: ora puoi configurare la dimensione dell'icona del desktop e la dimensione del carattere in Desktop > Barra delle applicazioni > Opzioni > Sfondo.
File Station
- È ora possibile condividere una cartella condivisa tramite un collegamento di condivisione.
Switch di rete e virtuale - Switch
di rete e virtuale ora visualizza i valori MTU (Maximum Transmission Unit) per le interfacce di rete.
SAMBA
- QTS ora supporta il protocollo di ricerca di Microsoft Windows. Ciò consente di eseguire ricerche rapide di file e cartelle nelle cartelle condivise NAS montate su Windows 10 tramite SMB.
Storage&Snapshots
- Storage & Snapshots ora visualizza i diagrammi della topologia per gli alloggiamenti di espansione SAS JBOD per aiutare a visualizzare la disposizione dei dispositivi di archiviazione.
- Per garantire la disponibilità dei tuoi dati, Storage & Snapshots ora supporta "Sostituisci e scollega", che ti consente di copiare i dati da un disco difettoso a un disco di riserva e quindi staccare in modo sicuro il disco difettoso.
- Ora puoi utilizzare exFAT su modelli basati su ARM senza acquistare una licenza exFAT. Nota che abbiamo già aggiunto questo supporto per i modelli basati su x86 in un aggiornamento precedente.
[Miglioramento]
- Aggiunta un'opzione per forzare gli utenti a modificare la propria password al primo accesso.
- Aggiunte le seguenti funzionalità nel Pannello di controllo per ottimizzare il meccanismo e il flusso di lavoro degli aggiornamenti del firmware:
* Impostazioni di aggiornamento in tempo reale unite e impostazioni di aggiornamento automatico in un'unica interfaccia utente.
* Notifiche avanzate per gli aggiornamenti del firmware. Gli utenti possono scegliere di posticipare o annullare gli aggiornamenti prima dell'orario di aggiornamento pianificato.
* Introdotto un nuovo tipo di aggiornamento: importanti aggiornamenti di sicurezza. Ti consigliamo di selezionare questo tipo di aggiornamento nelle impostazioni di aggiornamento automatico per garantire la sicurezza del tuo dispositivo.
- QTS ora visualizza un messaggio di avviso in Pannello di controllo > Sistema > Hardware > Risorse hardware quando si seleziona una scheda grafica installata su uno slot PCIe che non supporta il passthrough PCIe.
- Quando si importano utenti, ora è possibile scegliere di richiedere agli utenti importati di modificare la propria password al primo accesso.
- Ridotto il periodo di attesa per gli aggiornamenti automatici del firmware. QTS ora avvia un aggiornamento automatico entro solo un'ora dall'orario programmato se è disponibile una nuova versione del firmware per il dispositivo.
- Gli amministratori ora possono scegliere di ricevere notifiche all'accesso se è disponibile un aggiornamento firmware consigliato. (Questa funzione è abilitata per impostazione predefinita).
File Station
- File Station ora può convertire i file Apple iWork nei formati Microsoft Office con CloudConvert API v2.
- Ottimizzati i risultati dell'ordinamento dei nomi dei file per tutte le lingue. Questo aiuta a fornire risultati di ordinamento più coerenti.
- File Station ora fornisce maggiori informazioni per le attività in background per aiutarti a comprendere i dettagli, lo stato e l'avanzamento di ciascuna attività.
- I collegamenti di condivisione ora mostrano le miniature dei file e ti consentono di selezionare e scaricare più file contemporaneamente. Abbiamo anche migliorato il design dell'interfaccia utente per migliorare la tua esperienza di condivisione dei file.
: jQuery aggiornato a 3.5.1.
- Migliorate le informazioni per il gateway predefinito del sistema e l'NCSI (Indicatore di stato della connettività di rete) in Network & Virtual Switch per spiegare meglio i loro comportamenti.
- I modelli TS-x77XU e TS-x83XU possono ora aggiornare il firmware per le loro schede di interfaccia di rete tramite Advanced Network Driver.
Modulo di sistema PHP
- Aggiornata la versione PHP integrata alla 7.4.20.
SAMABA
- Gli utenti ora possono abilitare la firma SMB per i dispositivi NAS che non fanno parte di un dominio. Per abilitare questa impostazione, vai su Pannello di controllo > Servizi di rete e file > Win/Mac/NFS/WebDAV > Rete Microsoft > Opzioni avanzate.
Storage&Snapshots
- Seagate IronWolf Health Management (IHM) aggiornato alla versione 1.3.13 per aggiungere il supporto per i seguenti modelli di unità: IronWolf 525 SSD 2TB(ZP2000NM30002), IronWolf 525 SSD 1TB(ZP1000NM30002), IronWolf 525 SSD 500GB(ZP500NM30002), IronWolf 16TB( ST16000VN001), IronWolf 14TB(ST14000VN0008).
- Archiviazione e snapshot ora supporta lo zoom sui disegni del modello hardware per visualizzare i dettagli dei componenti.
[Problemi noti]
- macOS Finder impiega molto tempo per visualizzare i contenuti nelle cartelle condivise SMB quando gli utenti collegano il Mac al NAS tramite Thunderbolt. Questo problema potrebbe essere dovuto a problemi con il driver del dispositivo Mac. Si verifica solo su dispositivi Mac con processori Intel e macOS 11 (o versioni successive).
- QTS e QuTS hero con versioni del kernel più recenti non supportano gli adattatori Fibre Channel ATTO. Se hai già installato un adattatore ATTO Fibre Channel sul tuo dispositivo, ti sconsigliamo di aggiornare il firmware a QTS 5.0.0 o QuTS hero h5.0.0 per il momento.
- Il pannello di controllo non può visualizzare le informazioni della TPU installata nello slot M.2 sul QGD-1602P.
[Altre modifiche]
App Center
- Per motivi di sicurezza, QTS non supporta più l'aggiunta di collegamenti alle app nella schermata di accesso.
- In App Center, l'opzione "Consenti installazione di applicazioni senza una firma digitale valida" è ora disabilitata per impostazione predefinita dopo l'aggiornamento del firmware.
- Rimosse alcune informazioni sul dispositivo dalla schermata di accesso per migliorare la sicurezza del dispositivo.
- Per garantire la sicurezza del dispositivo, l'account "admin" non può utilizzare la password predefinita (l'indirizzo MAC della prima scheda di rete) durante la modifica della password.
Desktop e accesso
- Invece di utilizzare l'alias generico "utente app", QuLog Center e Desktop Dashboard ora mostrano i nomi utente effettivi quando gli utenti accedono a risorse e servizi di sistema tramite un'app client.
- Per migliorare la sicurezza del dispositivo, il sistema ora chiede all'utente "admin" di modificare la password quando l'utente accede con la password predefinita (l'indirizzo MAC della prima scheda di rete).
Licenza
: non è più necessaria una licenza per utilizzare QuTScloud installato in Virtualization Station. Tieni presente che per questa modifica è richiesto License Center 1.7.5 (o successivo).
SAMBA
- La versione SMB più bassa è ora SMB 2 per impostazione predefinita.
Archiviazione e istantanee
- Per un flusso di lavoro più intuitivo, Archiviazione e istantanee ora mostra varie opzioni (come "Rimuovi" ed "Espandi") nel menu "Azione" in Gestione pool/volume.
- Storage & Snapshots ora fornisce informazioni più chiare sui risultati dei test IronWolf Health Management (IHM). Ciò ti consente di controllare facilmente lo stato delle tue unità IronWolf.
- Ora puoi identificare e riparare rapidamente i volumi che potrebbero presentare potenziali problemi dopo un'interruzione di corrente o uno spegnimento anomalo. In Archiviazione e snapshot > Panoramica, ora aggiungiamo un collegamento che consente di eseguire un controllo del file system su tali volumi.
Re: QTS 5.0.1 beta pubblica
Ottima beta.
Gabriel.83
Messaggio da Gabriel.83 »
Mi sembra una buona beta, però da che si è aggiornato il mio NAS (TS-453B), non mi va più aMule. Voi sapete per caso come posso risolvere?
amule non viene aggiornato da tre anni, è già tanto se si installa
Su questa versione si disattivano dopo un po che sono accese tutte le app che non hanno la firma digitale valida. Basta poi andare dentro app center per riattivarle.
Le app che si disattivano sono:
Adguard
Emby
tvheadent
se ne avete altre segnalatele
lucam1970
Messaggio da lucam1970 »
Sul forum in lingua inglese due utenti segnalano il brick del proprio NAS, rispettivamente un TVS-463 e un TVS-863+
Per notizia
Gabriel.83
Segnalo che a me si disattivano anche:
CodexPack
QIoT Suite
Per entrambe pare che la firma digitale sia scaduta e a volte ripartono, altre volte no.
P.S. vero che amule non lo aggiornano più da un sacco di tempo, ma qualcuno sa indicarmi un'altra app P2P (a parte Download Station) che sia compatibile con questo firmware? Inoltre segnalo che non è nemmeno più possibile re-installare amule 2.3.3.2 (che è l'ultima versione che sono riuscito a trovare in internet)
CodexPack non vine più sviluppato e il suo progetto annullato, per via dei vari diritti d'autore dei produttori. Ora devi installare Cayin Media Sign Player per il supporto del codec. https://software.qnap.com/cayin-mediasign-player.html
su vuoi amule lo puoi installare sulla container station.
Se guardi nei tutorial ci sono le guide.
Per quelli che hanno il problema della disattivazione delle app senza firma digitale valida, il problema si trova nella spunta delle impostazioni dell'app center, consenti installazione di applicazioni.....
Immagine
Per chi lo ha disattivato, basta che mette la spunta e applica. Per chi lo ha attivo, deve togliere la spunta, applicare, rimettere la spunta e applicare di nuovo, così facendo riparte correttamente. Fino adesso nel mio nas non sta dando problemi!
E' chiaro che Qnap ha avuto problemi di sicurezza in questi ultimi mesi, e deve recuperare un bel po' di credibilità, perciò certe app saranno non funzionanti o funzioneranno a vostro rischio.
Controllate nel pannello di controllo la voce di aggiornamento firmware, li dentro c'è una nuova disposizione delle voci, vedete se sono tarate come vi servono o vanno spostate
jim27
Messaggio da jim27 »
@ Selvaggi:
Ciao a tutti, e come si fa per aggiornare il Licence Center?
Licenza
Licence Center si installa e/o aggiorna dall' app center come si fa di solito, se guardi sui tutorial trovi anche la guida
In questa versione sono cambiate le impostazioni "Protezione accesso IP" in caso di accesso non autorizzato, è stata aggiunta la voce RTRR e la voce Rsync, vi consiglio di andare dentro il pannello di controllo alla voce sicurezza e controllare se è tarato nel modo giusto in base alle vostre necessità.
jim27
selvaggi ha scritto: 10 giu 2022, 10:36 Licence Center si installa e/o aggiorna dall' app center come si fa di solito, se guardi sui tutorial trovi anche la guida
Licenza
Come si fa ad aggiornare il Centro Licenze alla versione 1.7.5 , visto che sul mio Qnap TS-253B ho installata la versione 1.7.17 con il nuovo Firmware Beta QTS 5.0.1.2034??
Ho provato ad installare QUTSCLOUD in Virtualization Station, ma mi chiede la licenza
Qualcuno e' riuscito? Tu Selvaggi sei riuscito?
Grazie e saluti
Uscita QTS 5.0.1.2079 build 20220629 Public Beta 2 come sempre in area download
- HS-251+, S2
- QMiroPlus-201W
- Mustang-200, Mustang-F100, Mustang-V100, Mustang-200-i7-1T-32G-R10, Mustang -200-i5-1T-32G-R10, Mustang-200-C-8G-R10
- QBoat Sunny
- QGD-3014-16PT
- TS-453S Pro,TS-853S Pro
- TS-531P
- TS-128A,TS- 228A,TS-212P3,TS-130,D1 Rev-B
- TS-231P3,TS-431P3
- TS-231P2,TS-431P2
- TS-831X,TS-531X,TS-831X v2,TS-431X,TS- 431X2,TS-431X3,TS-431KX
- TS-431XU,TS-831XU,TS-1231XU,TS-431XU-RP,TS-831XU-RP,TS-1231XU-RP,TS-431XeU
- TS-932X,TS- 832X,TS-332X,TS-532X,TS-932PX,TS-832PX
- TS-1635
- TS-1635AX
- TS-251B
- TS-451U
-TS-453Bmini,TS-253B,TS-453B,TS-653B,TS-253Be,TS-453Be, TS-453BT3
-TS-853BU,TS-853BU-RP,TS-1253BU,TS-1253BU-RP,TS-453BU,TS-453BU-RP
- HS-453DX,TBS-453DX,TS-251D,TS-253D,TS-653D ,TS-453D,TS-451D,TS-453Dmini,TS-451D2
- TBS-453A,TS-253A,TS-453A,TS-653A,TS-853A,D6 Pro,D8 Pro
- TS-453U,TS-853U ,TS-1253U,TS-453U-RP,TS-853U-RP,TS-1253U-RP,R4
- TVS-463,TVS-663,TVS-863,TVS-863+,TS-563,TS-963X, TS-963N
-TS-463U,TS-463U-RP,TS-863U,TS-863U-RP,TS-1263U,TS-1263U-RP,TS-463XU,TS-463XU-RP,TS-863XU,TS- 863XU-RP, TS-1263XU, TS-1263XU-RP
- TS-564, HS-264, TBS-464, TS-262C, TS-462C, TS-262, TS-462, TS-264C, TS-464C, TS-364,TS-264,TS-464,TS-664
- TS-464U,TS-464U-RP,TS-1264U-RP,TS-464eU,TS-864eU,TS-864eU-RP
- TVS-471, TVS-671,TVS-871, TVS-871T
-TVS-871U-RP,TVS-1271U-RP,TVS-471U-RP,TVS-471U,R8
-TVS-672N,TVS-872N,TVS-872X,TVS-672X,TVS-472X,TVS-472XT,TVS-672XT,TVS-872XT
- TVS-872XU,TVS-872XU-RP,TVS-1272XU-RP,TVS -1672XU-RP,TVS-2472XU-RP,TVS-972XU,TVS-972XU-RP
- TVS-473,TVS-673,TVS-873,TVS-473e,TVS-673e,TVS-873e
- TS-h973AX,TS -473A,TS-673A,TS-873A
- TS-873AU,TS-873AU-RP,TS-1273AU-RP,TS-1673AU-RP,TS-873AeU,TS-873AeU-RP
- TS-873U,TS-1273U ,TS-1673U,TS-873U-RP,TS-1273U-RP,TS-1673U-RP
- TVS-675
- TVS-h875U,TVS-h875U-RP,TVS-h1275U-RP,TVS-h1675U-RP
- TS -1277,TS-877,TS-677,TS-1677X
- TS-877XU,TS-1277XU,TS-1677XU,TS-877XU-RP,TS-1277XU-RP,TS-1677XU-RP,TS-2477XU-RP ,TS-977XU-RP,TS-977XU,TS-h1277XU-RP,TS-h977XU-RP,TS-h1677XU-RP,TS-h2477XU-RP
-TS-EC880 Pro,TS-EC1080 Pro,TVS-EC880,TVS-EC1080,TVS-EC1080+ -TS
-EC880U,TS-EC1280U,TS-EC1680U,TS-EC2480U R2,TVS-EC1280U-SAS-RP R2,TVS -EC1580MU-SAS-RP R2,TVS-EC1680U-SAS-RP R2,TVS-EC2480U-SAS-RP R2,TS-EC2480U,TS-EC880U R2,TS-EC1280U R2,TS-EC1680U R2,TVS-EC1280U-SAS -RP,TVS-EC1580MU-SAS-RP,TVS-EC1680U-SAS-RP,TVS-EC2480U-SAS-RP,R12,R16,R24
- TVS-682,TVS-882,TVS-1282,TVS-882BR,TVS -882T,TVS-1282T,TVS-682T,TVS-1282T3,TVS-882BRT3
- TVS-1582TU
- TS-883XU,TS-883XU-RP,TS-1283XU-RP,TS-1683XU-RP,TS-983XU,TS -983XU-RP,TS-2483XU-RP,TS-h1283XU-RP,TS-h2483XU-RP,TS-h1683XU-RP
- TES-3085U,TES-1885U,TS -1886XU-RP,TS-h1886XU-RP,TS-1886XU-RP R2,TS-h1886XU-RP R2
- TDS-16489U
- TS-h2490FU
- TS-328,TS-428,TS-230,D2 Rev-B
- TS-551
- TS-473,TS-673,TS-873
- TVS-951X,TVS-951N
- GM-1000, TNS-h1083X,TNS-h1083X (lato A),TNS-h1083X (lato B),TNS-h1083X (lato A),TNS-h1083X (lato B)
- TS-216,TS-416
- TS-435XeU
- TVS- 882ST,TVS-882ST3
- TS-i410X
- TS-h1290FX
[Note importanti]
- Ora puoi scegliere di disabilitare le porte USB per bloccare l'uso di tutti i dispositivi USB o solo dei dispositivi di archiviazione USB.
[Miglioramento]
- Il criterio UPS predefinito è ora impostato su "modalità di protezione automatica" dopo l'inizializzazione del NAS.
- Ora puoi creare un programma di alimentazione una tantum.
- Migliorata l'interfaccia utente di Snapshot Replica per migliorare ulteriormente l'usabilità e l'esperienza utente.
[Problemi risolti]
- Risolto un problema per cui gli utenti a volte non potevano connettersi a LUN iSCSI basati su file tramite il server VMware ESXi 5.5.
- Risolto un problema per cui gli utenti non riuscivano a trovare il NAS in Esplora file di Windows > Rete dopo aver abilitato WireGuard VPN Server nel servizio QVPN.
- Risolto un problema in Rete e switch virtuale per cui i percorsi statici scomparivano occasionalmente quando gli utenti stabilivano connessioni VPN e creavano processi di sincronizzazione in HBS3.
- Risolto un problema per cui il pannello LCD del TL-D1600S visualizzava il nome del dispositivo in modo errato.
- Risolto un problema per cui gli utenti non potevano sfogliare i file condivisi tramite i collegamenti di condivisione di File Station durante l'utilizzo di Firefox.
- Risolto un problema per cui i dischi rigidi sul NAS a volte si avviavano quando il NAS veniva spento dopo che gli utenti avevano ricollegato il cavo di alimentazione.
- Risolto un problema per cui a QuLog Center mancava un messaggio di registro sull'incoerenza della versione del firmware tra il sistema e un'unità installata.
- Risolto un problema che impediva agli utenti di creare nuovamente un pool di archiviazione SED dopo aver rimosso un pool di archiviazione SED e quindi riavviato il NAS.
- Risolto un problema per cui il NAS non riusciva a rilevare correttamente la scheda di espansione di rete QXG-10G2SF-NXE dopo che gli utenti avevano aggiornato QTS a 5.0.0.1891.
- Risolto un problema per cui l'attributo del file "nascosto" veniva disabilitato dopo che gli utenti avevano copiato i file nascosti da Windows 10 al NAS.
- Risolto un problema che impediva al NAS di rispondere quando gli utenti cercavano un numero elevato di file UTF-8 tramite SSH su un'unità esterna HFS+.
- Risolto un problema in Archiviazione e snapshot per cui l'esportazione LUN a volte falliva a causa di errori imprevisti.
- Risolto un problema nelle autorizzazioni utente che causava il fallimento dei processi di replica snapshot.
- Risolto un problema per cui gli utenti non potevano creare una cartella in un'unità esterna formattata in FAT32 o exFAT durante la connessione all'unità esterna tramite AFP.
- Risolto un problema in iSCSI e Fibre Channel per cui gli utenti occasionalmente non potevano espandere correttamente iSCSI LUN.
- Risolto un problema che causava tempi di accesso prolungati in un ambiente con un numero elevato di utenti di dominio e gruppi di dominio.
- Risolto un problema per cui il Pannello di controllo non poteva visualizzare alcuna informazione DNS nelle impostazioni del controller di dominio dopo che gli utenti avevano rimosso gli amministratori di dominio dai gruppi di amministratori.
- Risolto un problema per cui il Pannello di controllo continuava a visualizzare le autorizzazioni di accesso alle cartelle per gli UID (identificatori utente) anche dopo che gli account utente erano stati eliminati.
- Risolto un problema che impediva agli utenti di creare uno storage pool SED.
- Risolto un problema per cui la scheda di espansione di rete QXG-10G2T-107 non poteva rispondere dopo che gli utenti hanno aggiornato il firmware.
- Risolto un problema per cui gli utenti non potevano copiare correttamente un file da una macchina virtuale Ubuntu (in esecuzione in Virtualization Station) in una cartella in Windows.
- Risolto un problema per cui gli utenti non potevano aprire direttamente file PDF/DOC/PPT sul sito Web myQNAPcloud con un browser web.
- Risolto un problema che impediva agli utenti di avviare il NAS senza dischi.
- Risolto un problema per cui gli utenti non potevano accedere alle cartelle condivise del NAS da uno dei Mac quando si collegavano due Mac a un NAS e un contenitore di espansione tramite un collegamento a margherita Thunderbolt.
- Risolto un problema che influiva sulle prestazioni di Thunderbolt quando gli utenti accedevano alle cartelle condivise SMB tramite Thunderbolt.
[Problemi noti]
- QTS e QuTS hero con le versioni del kernel più recenti non supportano gli adattatori Fibre Channel ATTO. Se hai già installato un adattatore ATTO Fibre Channel sul tuo dispositivo, ti consigliamo di non aggiornare il firmware a QTS 5.0.0 o QuTS hero h5.0.0 per il momento.
- Gli utenti non possono eseguire test SMART per monitorare lo stato del disco dopo che TS-x53 Pro si è riattivato dalla modalità di sospensione.
- Le velocità di scrittura Thunderbolt sul TS-453BT3 sono inferiori al previsto dopo che gli utenti hanno aggiornato QTS da 4.5.4 (o precedenti) a 5.0.1.
[Altre modifiche]
- VJBOD attualmente non supporta LUN crittografati.
lollodragon
Messaggio da lollodragon »
selvaggi ha scritto: 22 mag 2022, 13:44 CodexPack non vine più sviluppato e il suo progetto annullato, per via dei vari diritti d'autore dei produttori. Ora devi installare Cayin Media Sign Player per il supporto del codec. https://software.qnap.com/cayin-mediasign-player.html
Ciao! Mi potresti dare il link per il tutorial su Amule in Container Station? Non sono riuscito a trovarlo in nessun modo.
GRAZIE MILLE!!! : Wink :
QNAP TVS-h1288X
8x6TB WDC RAID 5
