Ho ricevuto una mail da qnap in cui mi si invitava a verificare qualcsa sulla sicurezza attraverso il "Security Counselor".
Cos'è e dove si trova? c'è anche sul ts-212 o no?
ecco la mail.
Take Immediate Actions to Stop Your NAS from Exposing to the Internet, and Fight Against Ransomware Together
Taipei, Taiwan, January 26, 2022 - QNAP® Systems, Inc. (QNAP) today issued a statement in response to a new type of ransomware named DeadBolt. DeadBolt has been widely targeting all NAS exposed to the Internet without any protection and encrypting users’ data for Bitcoin ransom. QNAP urges all QNAP NAS users to follow the security setting instructions below to ensure the security of QNAP NAS and routers, and immediately update QTS to the latest available version.
If your NAS login page is hacked, please try to add "/cgi-bin/index.cgi" to the NAS login URL (e.g. http://nas_ip:8080/cgi-bin/index.cgi), and you should log in accordingly. Please contact QNAP Technical Support for further assistance at https://service.qnap.com/.
Check whether your NAS is exposed to the Internet
Open the Security Counselor on your QNAP NAS. Your NAS is exposed to the Internet and at high risk if there shows “The System Administration service can be directly accessible from an external IP address via the following protocols: HTTP” on the dashboard.
QNAP NAS Secure
How to know which ports on the router are exposed to the Internet:
https://www.qnap.com/go/how-to/faq/arti ... e-internet
If your NAS is exposed to the Internet, please follow the instructions below to ensure NAS security:
Step 1: Disable the Port Forwarding function of the router
Go to the management interface of your router, check the Virtual Server, NAT or Port Forwarding settings, and disable the port forwarding setting of NAS management service port (port 8080 and 443 by default).
QNAP NAS Secure
Step 2: Disable the UPnP function of the QNAP NAS
Go to myQNAPcloud on the QTS menu, click the “Auto Router Configuration”, and unselect "Enable UPnP Port forwarding".
QNAP NAS Secure
Securely access your QNAP NAS via the Internet through myQNAPcloud Link:
https://www.qnap.com/go/solution/myqnapcloud-link/
Learn more about NAS remote access and network security:
https://www.qnap.com/go/solution/secure-remote-access/
About QNAP Systems, Inc.
QNAP (Quality Network Appliance Provider) is devoted to providing comprehensive solutions in software development, hardware design and in-house manufacturing. Focusing on storage, networking and smart video innovations, QNAP now introduce a revolutionary Cloud NAS solution that joins our cutting-edge subscription-based software and diversified service channel ecosystem. QNAP envisions NAS as being more than simple storage and has created a cloud-based networking infrastructure for users to host and develop artificial intelligence analysis, edge computing and data integration on their QNAP solutions.
Media Contacts
marketing@qnap.com
security counselor
Re: security counselor
Attenzione, i problemi continuano:
https://nascompares.com/2022/01/26/qnap ... ansomware/
