[BETA] QNAP Qsync for Mac
http://eu1.qnap.com/Storage/Utility/QNA ... 9_Beta.dmg
[Product ]
QNAP Qsync for Mac (Beta)
[Introduction]
Qsync is a cloud based file service empowered by QNAP Turbo NAS. Simply add files to your local Qsync folder, and they will be available on your Turbo NAS and all its connected devices.
[Version]
1.0.0 Build 1009
[Size]
6.7 MB
[New Features]
Syncs files among multiple devices through the NAS.
-Option for not removing files on the NAS during synchronisation.
-Support selective synchronisation.
-Shares files securely with SSL connection.
-Supports team folder.
-Supports local and domain users when sharing with team folders.
-Shares files by links via E-mail.
-Automatically uploads photos or videos to Qsync folder through Qfile.
-Restores files from network recycle bin
-File name conflict policy.
-Filter settings for file synchronisation.
-Privileges control for Qsync users."
[Change Logs]
First Beta release
[Known Issues]
-Qsync context menu can be found when click right mouse key on the file or folder outside the Qsync folder
-When share folder with LDAP users, the LDAP users won't get the information of the sharing so to cause sharing failure.
-Sometimes, the status icon of root folder does not reflect the status of sync completion on OS X v.10.8.5
-When the network is not stable or you restart computer, Qsync will do full scan to check files status. This will take long time when syncing large amount of files or folders.
[Supported Language]
English, Chinese-TW, Chinese-CS, Czech, Danish, Finnish, French, Hungarian, Italian, Japanese, Korean, Thai, Turkish, Russian, Romanian, Norwegian, Swedish, Polish, Portuguese, Dutch, Greek, Spanish, German
[Supported platform]
OS X v.10.8.5 & v.10.7.5
djmatto
Re: [BETA] QNAP Qsync for Mac
Messaggio da djmatto »
Hey,
I have a mac with mavericks and I don't know how to change the language beacause I don't understand anything with this language.
I add a screenshot of dropdown menu.
Thanks for everyone helps me
Dropdown menu screen
Schermata 2013-10-30 alle 17.49.33.png (55.57 KiB) Visto 4164 volte
djmatto, u can find temporary work around here. The problem is known n will b fixed in the next beta/official release.
P.S. if u can speak italian pls post in italian, otherwise use the official english forum instead, thanks.
Ivan333
Messaggio da Ivan333 »
Wizard di istallazione
Ciao a tutti : Welcome : !
Vero che Qsync è ancora in beta, ma perché non vengono fatte delle semplici correzioni di traduzione del menù.
Ho appena istallato l'aggiornamento alla relese 1.0.3.0513 e ci sono ancora molte parole in ungherese invece che in italiano, potrei capire se ci fossero delle parole in inglese, ma non in ungherese, che non è assolutamente comprensibile per chi non lo conosce! : Eeek :
Allego due screenshot per rafforzare quanto scritto..
un caro saluto, Ivan
Ivan333
Questo è dal menu dell'icona: ultime due righe prima di ESCI
Qsync icona.png (52.83 KiB) Visto 3770 volte
netbix
Messaggio da netbix »
Speriamo sistemino con una prossima versione.
Qnap TS-419P+ Turbo NAS -- Firmware : QTS 4.3.3 Build 20181029
2 HD 2 TB "Seagate ST2000DM001 + 2 HD 2 TB "Seagate ST2000VX000"
RAID 5
Ho segnalato la cosa, verrà corretto nel prossimo rilascio, grazie.
netbix
Grazie Luciano !
Spero risolvano anche i vari crash che avvengono nel mio Mac OS X 10.9.3, quando sincronizzo file da piattaforma windows, durante la sincronizzazione sul Mac il programma va in crash ! Lo devo riaprire 2 -3 volte e poi rimane attivo.
Proverò a fare altri test sincronizzando da due Mac.
RAID 5
netbix
Stesso problema, se sincronizzo su un mac poi nell'altro mentre il programma sincronizza va in crash !
Attendo aggiornamento
Tra windows e windows funziona bene.
RAID 5
