sto provando a compilare Amule Adunanza su Qnap TS 269L (processore intel)
Il configure mi trova tutte le dipendenze ma al momento della creazione del Makefile, gawk (4.0.1) mi da un errore di sintassi.
ecco il configure che lancio
Codice: Seleziona tutto
./configure --disable-alc --disable-alcc --disable-geoip --enable-optimize --disable-amulecmd --enable-amule-daemon --disable-amule-gui --disable-cas --disable-webserver --disable-wxcas --disable-monolithic --disable-debug --disable-upnp CXXFLAGS="-march=i686" --prefix=/opt
config.status: creating Makefile
gawk: ./confpT1y7T/subs.awk:2: S["/; s/!.*/"]=am__EXEEXT_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:2: ^ syntax error
gawk: ./confpT1y7T/subs.awk:3: S["/; s/!.*/"]=am__EXEEXT_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:3: ^ syntax error
gawk: ./confpT1y7T/subs.awk:4: S["/; s/!.*/"]=am__EXEEXT_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:4: ^ syntax error
gawk: ./confpT1y7T/subs.awk:4: S["/; s/!.*/"]=LTLIBOBJS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:5: S["/; s/!.*/"]=LTLIBOBJS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:5: ^ syntax error
gawk: ./confpT1y7T/subs.awk:5: S["/; s/!.*/"]=READLINE_LIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:6: S["/; s/!.*/"]=READLINE_LIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:6: ^ syntax error
gawk: ./confpT1y7T/subs.awk:7: S["/; s/!.*/"]=COMPILE_LIB_EC_FALSE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:7: ^ syntax error
gawk: ./confpT1y7T/subs.awk:7: S["/; s/!.*/"]=COMPILE_LIB_EC_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:8: S["/; s/!.*/"]=COMPILE_LIB_EC_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:8: ^ syntax error
gawk: ./confpT1y7T/subs.awk:9: S["/; s/!.*/"]=COMPILE_LIB_COMMON_FALSE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:9: ^ syntax error
gawk: ./confpT1y7T/subs.awk:9: S["/; s/!.*/"]=COMPILE_LIB_COMMON_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:10: S["/; s/!.*/"]=COMPILE_LIB_COMMON_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:10: ^ syntax error
gawk: ./confpT1y7T/subs.awk:10: S["/; s/!.*/"]=ENABLE_MRHYDEEXP_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:11: S["/; s/!.*/"]=ENABLE_MRHYDEEXP_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:11: ^ syntax error
gawk: ./confpT1y7T/subs.awk:12: S["/; s/!.*/"]=ENABLE_MRHYDEEXP_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:12: ^ syntax error
gawk: ./confpT1y7T/subs.awk:12: S["/; s/!.*/"]=ENABLE_ADUNSLU2_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:13: S["/; s/!.*/"]=ENABLE_ADUNSLU2_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:13: ^ syntax error
gawk: ./confpT1y7T/subs.awk:14: S["/; s/!.*/"]=ENABLE_ADUNSLU2_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:14: ^ syntax error
gawk: ./confpT1y7T/subs.awk:14: S["/; s/!.*/"]=PLASMAMULE_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:15: S["/; s/!.*/"]=PLASMAMULE_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:15: ^ syntax error
gawk: ./confpT1y7T/subs.awk:16: S["/; s/!.*/"]=PLASMAMULE_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:16: ^ syntax error
gawk: ./confpT1y7T/subs.awk:16: S["/; s/!.*/"]=INSTALL_SKINS_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:17: S["/; s/!.*/"]=INSTALL_SKINS_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:17: ^ syntax error
gawk: ./confpT1y7T/subs.awk:18: S["/; s/!.*/"]=INSTALL_SKINS_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:18: ^ syntax error
gawk: ./confpT1y7T/subs.awk:19: S["/; s/!.*/"]=GENERATE_FLEX_HEADER_FALSE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:19: ^ syntax error
gawk: ./confpT1y7T/subs.awk:19: S["/; s/!.*/"]=GENERATE_FLEX_HEADER_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:20: S["/; s/!.*/"]=GENERATE_FLEX_HEADER_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:20: ^ syntax error
gawk: ./confpT1y7T/subs.awk:21: S["/; s/!.*/"]=COMPILE_NLS_FALSE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:21: ^ syntax error
gawk: ./confpT1y7T/subs.awk:21: S["/; s/!.*/"]=COMPILE_NLS_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:22: S["/; s/!.*/"]=COMPILE_NLS_TRUE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:22: ^ syntax error
gawk: ./confpT1y7T/subs.awk:22: S["/; s/!.*/"]=NEED_CORESERVICES_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:23: S["/; s/!.*/"]=NEED_CORESERVICES_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:23: ^ syntax error
gawk: ./confpT1y7T/subs.awk:24: S["/; s/!.*/"]=NEED_CORESERVICES_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:24: ^ syntax error
gawk: ./confpT1y7T/subs.awk:24: S["/; s/!.*/"]=NEED_RC_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:25: S["/; s/!.*/"]=NEED_RC_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:25: ^ syntax error
gawk: ./confpT1y7T/subs.awk:26: S["/; s/!.*/"]=NEED_RC_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:26: ^ syntax error
gawk: ./confpT1y7T/subs.awk:26: S["/; s/!.*/"]=SYS_WIN32_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:27: S["/; s/!.*/"]=SYS_WIN32_FALSE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:27: ^ syntax error
gawk: ./confpT1y7T/subs.awk:28: S["/; s/!.*/"]=SYS_WIN32_TRUE!#%!_!# "#"
gawk: ./confpT1y7T/subs.awk:28: ^ syntax error
gawk: ./confpT1y7T/subs.awk:28: S["/; s/!.*/"]=DEBUGFLAG!%!_!# ""
gawk: ./confpT1y7T/subs.awk:29: S["/; s/!.*/"]=DEBUGFLAG!%!_!# ""
gawk: ./confpT1y7T/subs.awk:29: ^ syntax error
gawk: ./confpT1y7T/subs.awk:29: S["/; s/!.*/"]=KDE_MIME_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:30: S["/; s/!.*/"]=KDE_MIME_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:30: ^ syntax error
gawk: ./confpT1y7T/subs.awk:30: S["/; s/!.*/"]=KDE_ICON_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:31: S["/; s/!.*/"]=KDE_ICON_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:31: ^ syntax error
gawk: ./confpT1y7T/subs.awk:31: S["/; s/!.*/"]=KDE_MODULE_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:32: S["/; s/!.*/"]=KDE_MODULE_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:32: ^ syntax error
gawk: ./confpT1y7T/subs.awk:32: S["/; s/!.*/"]=KDE_SERVICE_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:33: S["/; s/!.*/"]=KDE_SERVICE_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:33: ^ syntax error
gawk: ./confpT1y7T/subs.awk:33: S["/; s/!.*/"]=KDE_APPLNK_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:34: S["/; s/!.*/"]=KDE_APPLNK_PATH!%!_!# ""
gawk: ./confpT1y7T/subs.awk:34: ^ syntax error
gawk: ./confpT1y7T/subs.awk:34: S["/; s/!.*/"]=KDE_HEADER_DIR!%!_!# ""
gawk: ./confpT1y7T/subs.awk:35: S["/; s/!.*/"]=KDE_HEADER_DIR!%!_!# ""
gawk: ./confpT1y7T/subs.awk:35: ^ syntax error
gawk: ./confpT1y7T/subs.awk:35: S["/; s/!.*/"]=KDE4_CONFIG!%!_!# ""
gawk: ./confpT1y7T/subs.awk:36: S["/; s/!.*/"]=KDE4_CONFIG!%!_!# ""
gawk: ./confpT1y7T/subs.awk:36: ^ syntax error
gawk: ./confpT1y7T/subs.awk:36: S["/; s/!.*/"]=QT_GUI_LIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:37: S["/; s/!.*/"]=QT_GUI_LIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:37: ^ syntax error
gawk: ./confpT1y7T/subs.awk:37: S["/; s/!.*/"]=QT_GUI_CXXFLAGS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:38: S["/; s/!.*/"]=QT_GUI_CXXFLAGS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:38: ^ syntax error
gawk: ./confpT1y7T/subs.awk:38: S["/; s/!.*/"]=QT_CORE_LIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:39: S["/; s/!.*/"]=QT_CORE_LIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:39: ^ syntax error
gawk: ./confpT1y7T/subs.awk:39: S["/; s/!.*/"]=QT_CORE_CXXFLAGS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:40: S["/; s/!.*/"]=QT_CORE_CXXFLAGS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:40: ^ syntax error
gawk: ./confpT1y7T/subs.awk:40: S["/; s/!.*/"]=QT_DBUS_LDFLAGS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:41: S["/; s/!.*/"]=QT_DBUS_LDFLAGS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:41: ^ syntax error
gawk: ./confpT1y7T/subs.awk:41: S["/; s/!.*/"]=QT_MOC!%!_!# ""
gawk: ./confpT1y7T/subs.awk:42: S["/; s/!.*/"]=QT_MOC!%!_!# ""
gawk: ./confpT1y7T/subs.awk:42: ^ syntax error
gawk: ./confpT1y7T/subs.awk:42: S["/; s/!.*/"]=SVNDATE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:43: S["/; s/!.*/"]=SVNDATE!%!_!# ""
gawk: ./confpT1y7T/subs.awk:43: ^ syntax error
gawk: ./confpT1y7T/subs.awk:44: S["/; s/!.*/"]=BFD_LIBS!-lbfd -liberty %!_!# "-lbfd -liberty "
gawk: ./confpT1y7T/subs.awk:44: ^ syntax error
gawk: ./confpT1y7T/subs.awk:45: S["/; s/!.*/"]=BFD_CPPFLAGS!-DHAVE_BFD%!_!# "-DHAVE_BFD"
gawk: ./confpT1y7T/subs.awk:45: ^ syntax error
gawk: ./confpT1y7T/subs.awk:45: S["/; s/!.*/"]=INCINTL!%!_!# ""
gawk: ./confpT1y7T/subs.awk:46: S["/; s/!.*/"]=INCINTL!%!_!# ""
gawk: ./confpT1y7T/subs.awk:46: ^ syntax error
gawk: ./confpT1y7T/subs.awk:46: S["/; s/!.*/"]=MONOLITHIC_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:47: S["/; s/!.*/"]=MONOLITHIC_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:47: ^ syntax error
gawk: ./confpT1y7T/subs.awk:47: S["/; s/!.*/"]=ALCC_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:48: S["/; s/!.*/"]=ALCC_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:48: ^ syntax error
gawk: ./confpT1y7T/subs.awk:48: S["/; s/!.*/"]=ALC_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:49: S["/; s/!.*/"]=ALC_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:49: ^ syntax error
gawk: ./confpT1y7T/subs.awk:49: S["/; s/!.*/"]=ED2K_MANPAGES!ed2k.1 ed2k.de.1 ed2k.es.1 ed2k.fr.1 ed2k.hu.1 ed2k.it.1 ed2k.ru.1 ed2k.tr.1%!_!# "ed2k.1 ed2k.de.1 ed2k.es.1 ed2k.fr.1 ed2k.hu.1 ed2k.it.1 ed2k.ru.1 ed2k.tr.1"
gawk: ./confpT1y7T/subs.awk:50: S["/; s/!.*/"]=ED2K_MANPAGES!ed2k.1 ed2k.de.1 ed2k.es.1 ed2k.fr.1 ed2k.hu.1 ed2k.it.1 ed2k.ru.1 ed2k.tr.1%!_!# "ed2k.1 ed2k.de.1 ed2k.es.1 ed2k.fr.1 ed2k.hu.1 ed2k.it.1 ed2k.ru.1 ed2k.tr.1"
gawk: ./confpT1y7T/subs.awk:50: ^ syntax error
gawk: ./confpT1y7T/subs.awk:50: S["/; s/!.*/"]=WXCAS_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:51: S["/; s/!.*/"]=WXCAS_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:51: ^ syntax error
gawk: ./confpT1y7T/subs.awk:51: S["/; s/!.*/"]=CAS_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:52: S["/; s/!.*/"]=CAS_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:52: ^ syntax error
gawk: ./confpT1y7T/subs.awk:52: S["/; s/!.*/"]=AMULE_GUI_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:53: S["/; s/!.*/"]=AMULE_GUI_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:53: ^ syntax error
gawk: ./confpT1y7T/subs.awk:53: S["/; s/!.*/"]=WEBSERVER_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:54: S["/; s/!.*/"]=WEBSERVER_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:54: ^ syntax error
gawk: ./confpT1y7T/subs.awk:54: S["/; s/!.*/"]=AMULECMD_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:55: S["/; s/!.*/"]=AMULECMD_MANPAGES!%!_!# ""
gawk: ./confpT1y7T/subs.awk:55: ^ syntax error
gawk: ./confpT1y7T/subs.awk:55: S["/; s/!.*/"]=AMULE_DAEMON_MANPAGES!amuled.1 amuled.de.1 amuled.es.1 amuled.fr.1 amuled.hu.1 amuled.it.1 amuled.ru.1 amuled.tr.1%!_!# "amuled.1 amuled.de.1 amuled.es.1 amuled.fr.1 amuled.hu.1 amuled.it.1 amuled.ru.1 amuled.tr.1"
gawk: ./confpT1y7T/subs.awk:56: S["/; s/!.*/"]=AMULE_DAEMON_MANPAGES!amuled.1 amuled.de.1 amuled.es.1 amuled.fr.1 amuled.hu.1 amuled.it.1 amuled.ru.1 amuled.tr.1%!_!# "amuled.1 amuled.de.1 amuled.es.1 amuled.fr.1 amuled.hu.1 amuled.it.1 amuled.ru.1 amuled.tr.1"
gawk: ./confpT1y7T/subs.awk:56: ^ syntax error
gawk: ./confpT1y7T/subs.awk:57: S["/; s/!.*/"]=POSUB!po%!_!# "po"
gawk: ./confpT1y7T/subs.awk:57: ^ syntax error
gawk: ./confpT1y7T/subs.awk:57: S["/; s/!.*/"]=LTLIBINTL!%!_!# ""
gawk: ./confpT1y7T/subs.awk:58: S["/; s/!.*/"]=LTLIBINTL!%!_!# ""
gawk: ./confpT1y7T/subs.awk:58: ^ syntax error
gawk: ./confpT1y7T/subs.awk:58: S["/; s/!.*/"]=LIBINTL!%!_!# ""
gawk: ./confpT1y7T/subs.awk:59: S["/; s/!.*/"]=LIBINTL!%!_!# ""
gawk: ./confpT1y7T/subs.awk:59: ^ syntax error
gawk: ./confpT1y7T/subs.awk:59: S["/; s/!.*/"]=INTLLIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:60: S["/; s/!.*/"]=INTLLIBS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:60: ^ syntax error
gawk: ./confpT1y7T/subs.awk:60: S["/; s/!.*/"]=INTL_LIBTOOL_SUFFIX_PREFIX!%!_!# ""
gawk: ./confpT1y7T/subs.awk:61: S["/; s/!.*/"]=INTL_LIBTOOL_SUFFIX_PREFIX!%!_!# ""
gawk: ./confpT1y7T/subs.awk:61: ^ syntax error
gawk: ./confpT1y7T/subs.awk:62: S["/; s/!.*/"]=GENCAT!gencat%!_!# "gencat"
gawk: ./confpT1y7T/subs.awk:62: ^ syntax error
gawk: ./confpT1y7T/subs.awk:62: S["/; s/!.*/"]=INSTOBJEXT!.mo%!_!# ".mo"
gawk: ./confpT1y7T/subs.awk:63: S["/; s/!.*/"]=INSTOBJEXT!.mo%!_!# ".mo"
gawk: ./confpT1y7T/subs.awk:63: ^ syntax error
gawk: ./confpT1y7T/subs.awk:64: S["/; s/!.*/"]=DATADIRNAME!share%!_!# "share"
gawk: ./confpT1y7T/subs.awk:64: ^ syntax error
gawk: ./confpT1y7T/subs.awk:64: S["/; s/!.*/"]=INTLOBJS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:65: S["/; s/!.*/"]=INTLOBJS!%!_!# ""
gawk: ./confpT1y7T/subs.awk:65: ^ syntax error
gawk: ./confpT1y7T/subs.awk:65: S["/; s/!.*/"]=CATOBJEXT!.gmo%!_!# ".gmo"
gawk: ./confpT1y7T/subs.awk:66: S["/; s/!.*/"]=CATOBJEXT!.gmo%!_!# ".gmo"
gawk: ./confpT1y7T/subs.awk:66: ^ syntax error
gawk: ./confpT1y7T/subs.awk:67: S["/; s/!.*/"]=USE_INCLUDED_LIBINTL!no%!_!# "no"
gawk: ./confpT1y7T/subs.awk:67: ^ syntax error
gawk: ./confpT1y7T/subs.awk:68: S["/; s/!.*/"]=BUILD_INCLUDED_LIBINTL!no%!_!# "no"
gawk: ./confpT1y7T/subs.awk:68: ^ syntax error
gawk: ./confpT1y7T/subs.awk:69: S["/; s/!.*/"]=USE_NLS!yes%!_!# "yes"
gawk: ./confpT1y7T/subs.awk:69: ^ syntax error
gawk: ./confpT1y7T/subs.awk:70: S["/; s/!.*/"]=INTLBISON!bison%!_!# "bison"
gawk: ./confpT1y7T/subs.awk:70: ^ syntax error
gawk: ./confpT1y7T/subs.awk:70: S["/; s/!.*/"]=LTLIBICONV!%!_!# ""
gawk: ./confpT1y7T/subs.awk:71: S["/; s/!.*/"]=LTLIBICONV!%!_!# ""
gawk: ./confpT1y7T/subs.awk:71: ^ syntax error
gawk: ./confpT1y7T/subs.awk:71: S["/; s/!.*/"]=LIBICONV!%!_!# ""
gawk: ./confpT1y7T/subs.awk:72: S["/; s/!.*/"]=LIBICONV!%!_!# ""
gawk: ./confpT1y7T/subs.awk:72: ^ syntax error
gawk: ./confpT1y7T/subs.awk:73: S["/; s/!.*/"]=GLIBC21!yes%!_!# "yes"
gawk: ./confpT1y7T/subs.awk:73: ^ syntax error
gawk: ./confpT1y7T/subs.awk:74: S["/; s/!.*/"]=MSGMERGE!/opt/bin/msgmerge%!_!# "/opt/bin/msgmerge"
gawk: ./confpT1y7T/subs.awk:74: ^ syntax error
gawk: ./confpT1y7T/subs.awk:75: S["/; s/!.*/"]=XGETTEXT!/opt/bin/xgettext%!_!# "/opt/bin/xgettext"
gawk: ./confpT1y7T/subs.awk:75: ^ syntax error
gawk: ./confpT1y7T/subs.awk:76: S["/; s/!.*/"]=GMSGFMT!/opt/bin/msgfmt%!_!# "/opt/bin/msgfmt"
gawk: ./confpT1y7T/subs.awk:76: ^ syntax error
gawk: ./confpT1y7T/subs.awk:77: S["/; s/!.*/"]=MSGFMT!/opt/bin/msgfmt%!_!# "/opt/bin/msgfmt"
gawk: ./confpT1y7T/subs.awk:77: ^ syntax error
gawk: ./confpT1y7T/subs.awk:77: S["/; s/!.*/"]=MKINSTALLDIRS!./mkinstalldirs%!_!# "./mkinstalldirs"
gawk: ./confpT1y7T/subs.awk:77: ^ unterminated string
config.status: error: could not create Makefile
Qui il config.log: http://pastebin.com/raw.php?i=K1REmd5Y
Qui il config.status: http://pastebin.com/raw.php?i=anhCnFEN
Qualcuno potrebbe darci un occhio?
