Squid Transparent Proxy
enigma_lan
Messaggio da enigma_lan »
Ciao a tutti , sto cercando di configurare Squid come trasparent proxy con autenticazione sul mio nas , il mio scopo e quello di far navigare i computer della mia rete passando per forza attraverso il proxy senza che si vanno a modificare le impostazione del browser Web .
il Nas ha un indirizzo ip statico , e il router ha il server DHCP attivato
La mia prova e stata la porta "eth1" del nas collegata al router mentra la "eth2" allo switch , poi ho aggiunto nel file squid.conf la riga http_port 3128 transparent
Vi riporto la configurazione del mio file squid.conf
Codice: Seleziona tutto
# The uer name and group name Squid will operate as
cache_effective_user httpdusr
cache_effective_group everyone
# Recommended minimum configuration:
# Auth Method
auth_param basic program /opt/libexec/squid/ncsa_auth /etc/shadow
auth_param basic children 5
auth_param basic realm Server Proxy
auth_param basic credentialsttl 2 hours
acl manager proto cache_object
acl localhost src 127.0.0.1/32 ::1
acl to_localhost dst 127.0.0.0/8 0.0.0.0/32 ::1
# Example rule allowing access from your local networks.
# Adapt to list your (internal) IP networks from where browsing
# should be allowed
acl localnet src 10.0.0.0/8	# RFC1918 possible internal network
acl localnet src 172.16.0.0/12	# RFC1918 possible internal network
acl localnet src 192.168.0.0/16	# RFC1918 possible internal network
acl localnet src fc00::/7       # RFC 4193 local private network range
acl localnet src fe80::/10      # RFC 4291 link-local (directly plugged) machines
acl allnet src all		# All Net
acl SSL_ports port 443
acl Safe_ports port 80		# http
acl Safe_ports port 21		# ftp
acl Safe_ports port 443		# https
acl Safe_ports port 70		# gopher
acl Safe_ports port 210		# wais
acl Safe_ports port 1025-65535	# unregistered ports
acl Safe_ports port 280		# http-mgmt
acl Safe_ports port 488		# gss-http
acl Safe_ports port 591		# filemaker
acl Safe_ports port 777		# multiling http
acl CONNECT method CONNECT
acl ncsa_users proxy_auth REQUIRED
# Recommended minimum Access Permission configuration:
# Only allow cachemgr access from localhost
http_access allow manager localhost
http_access deny manager
# Deny requests to certain unsafe ports
http_access deny !Safe_ports
# Deny CONNECT to other than secure SSL ports
http_access deny CONNECT !SSL_ports
# We strongly recommend the following be uncommented to protect innocent
# web applications running on the proxy server who think the only
# one who can access services on \\\\\\\"localhost\\\\\\\" is a local user
#http_access deny to_localhost
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
# Adapt localnet in the ACL section to list your (internal) IP networks
# from where browsing should be allowed
# (QPKG Squid Config: User Access is \\\\\\\"No Restriction\\\\\\\" or \\\\\\\"Grant access to system user accounts\\\\\\\")
#http_access allow allnet
http_access allow allnet ncsa_users
# And finally deny all other access to this proxy
http_access deny all
# Squid normally listens to port 3128
# (QPKG Squid Config: HTTP port)
# We recommend you to use at least the following line.
hierarchy_stoplist cgi-bin ?
# Uncomment and adjust the following to add a disk cache directory.
# (QPKG Squid Config: Cache Directory)
cache_dir ufs /opt/var/squid/cache 20000 16 256
# (QPKG Squid Config: Cache Memory)
cache_mem 128 MB
# Leave coredumps in the first cache dir
coredump_dir /opt/var/squid/
access_log /opt/var/squid/logs/access.log squid
cache_log /opt/var/squid/logs/cache.log
cache_store_log /opt/var/squid/logs/store.log
# Add any of your own refresh_pattern entries above these.
refresh_pattern ^ftp:		1440	20%	10080
refresh_pattern ^gopher:	1440	0%	1440
refresh_pattern -i (/cgi-bin/|\\\\\\\\?) 0	0%	0
refresh_pattern .		0	20%	4320
Il problema e che con questa configurazione non riesco a navigare su internet , non mi viene assegnato un indirizzo ip , anche se nelle impostazioni di rete metto manuale e setto
Indirizzo IP: 192.168.1.X
Maschera: 255.255.255.0
Gateway: IP Server NAS
Cmq non riesco a navigare .
Dove sbaglio? Problema del DHCP? : Frown : Qualcuno ha mai provato a fare questo tipo di configurazione?
Qnap - TS-459 Pro 4x3 WD RED in RAID 5 (BACKUP)
Qnap - TS-473 4x6 WD Purple in RAID 5 , SODIMM -- > 32 GB HyperX HX424S14IBK2/32 ,Geforce GTX 1050 Ti --> always the last firmware
Firewall pFsense
miram
Re: Squid Transparent Proxy
Messaggio da miram »
Ciao, mi sono appena iscritto perchè vorrei sapere se hai risolto. Io con squid mi trovo benissimo ma sulla rete che gestisco dove l'ho installato sotto IPCOP. Con lui attivo riesco a fornire internet in modo dignitoso a circa 90pc con una linea a 7M... : Wink : Vorrei attivarlo sul mio neo TS-112 (seppure con una sola porta) per rendere veloce la navigazione dai miei tre pc casalinghi però, come te, vorrei evitare di configurare il proxy nel browser... Marco
enigma_lan
: Welcome :
Ciao , che router stai utilizzando? Io ho un Linksys della Cisco "E4200" con firmware della Tomato ed ho risolto seguendo questa guida http://www.dd-wrt.com/wiki/index.php/Sq ... rent_Proxy , non importa quante schede di rete hai 1 o 2 . I contro sono che nel file log di squid non vedrai l indirizzo ip del computer , ma l'IP del router .
Personalmente questa cosa non mi è piaciuta tanto , e sono ritornato alla configurazione di base di Squid modificando solo qualche parametro, senza configurare il mio Router , quindi non sto utilizzando Squid come transparent Proxy .
Firewall pFsense
miram
beh, immagino, un po' macchinoso effettivamente! Nella rete dove lavoro non ho avuto questo problema: è bastato mettere la spunto su trasparent e quindi settare i pc con gateway che puntava sul pc linux (su cui ho montato ipcop con il plugin squid)... Non so se conviene farlo e settare solo i pc fissi sul proxy oppure lasciar stare, anche perchè a questo punto il ts112 rimarrebbe sempre acceso!...
Intanto grazie e buona domenica... ci penso...
miram
Mi son dimenticato di dirti che ho un Dlink DSL2640B...
enigma_lan
Di niente e un piacere .
Bhè , IPCOP ha un interfaccia grafica quindi volendo si può settare il tutto senza modificare codice e stringhe .
Mha anche qnap ha reso molto semplice la configurazione di squid sul nuovo firmware 3.6 con una piccola interfaccia grafica .
Purtroppo sul Dlink DSL2640B non gli puoi installare il firmware della Tomato e neppure quella DD-Wrt , quindi si deve trovare un alternativa . Sto utilizzando Squid sul il mio 459 in RAID5 anche se e sconsigliato e sinceramente mi trovo molto bene , sicuramente farò altre prove per cercare di configurare Squid come transparent Proxy è farlo funzionare come si deve . Vi terrò informati
Buona Domenica .
Firewall pFsense
