mi scarica l'aggiornamento però sembra che l'installazione non vada a buon fine
QPKG pyLoad Updater script
Info: Checking if pyload is installed...
Info: pyLoad installation directory found
Info: Checking if Optware/IPKG is installed...
Info: Optware found and unzip was installed.
Info: Checking if pyLoad is running ...
Info: pyLoad is not running
Info: Downloading the 0.4.7 version
Info: Download succesfull.
Info: Inflating the files
Info: Downloading the updated start/stop script
Info: Backing up the config file before proceeding with the udpate
mv: unable to rename `/share/HDA_DATA/.qpkg/pyload/module/config/configdir': No such file or directory
Info: Removing previous pyLoad files ...
Info: Copying over the pyLoad new version files ...
Info: Restoring the config file
mv: unable to rename `/share/Public/pyload_update.4.7/configdir': No such file or directory
Info: Changing QPKG version number ...
Info: Checking if interface port is set to 8100
Starting pyLoad
Daemon PID 5248"
qualche soluzione???
