VENDO Draytek 2830
VENDO Draytek 2830
AGGRIONATO FIRMWARE;
HO LO SCONTRINO DI ACQUISTO;
MUNITO DI CONFEZIONE ORIGINALE;
VENDO SICCOME PASSATO A VDSL 200 MB;
PERFETTAMENTE FUNZIONANTE.
ADSL/ADSL2+, 3G/4G and Broadband Router
Triple-WAN ports for ADSL, cable modem and 3G/4G
modem which can be used simultaneously
IPv4 and IPv6 Dual-Stack
V3 Firewall with huge flexibility
Four-Port Gigabit Ethernet LAN Switch
Multiple Private LAN Subnets
User Password Access Control
Up to 50,000 simultaneous NAT sessions
Up to 4 VLANs (Port or IP based)
VLAN Prioritisation & 802.1q
Twin VoIP ports with PSTN passthrough (Vigor2830Vn)
IGMP v3 MultiCast
Content Filtering (by matched keyword or data type)
Globalview Web Filtering (Subject to subscription)
Ethernet and WiFi VLANs (common/distinct groups)
QoS (Layer 2&3, 802.1p & TOS/DCSP)
SSH and HTTPS/AES Access to WUI
VPN Dial-in/dial-out with hardware co-processor
USB Port for Printer, Logs or compatible 3G/4G Modem
Optional VigorCare Available
- Allegati
- 2830_3.pdf
- (542.08 KiB) Scaricato 3 volte
- 2830_2.pdf
- (574.11 KiB) Scaricato 4 volte
- 2830_1.pdf
- (581.15 KiB) Scaricato 5 volte
UDM PRO - Ubiquiti -
Re: VENDO Draytek 2830
È ancora disponibile?
Inviato dal mio moto g(6) plus utilizzando Tapatalk
Si
