QTS 4.3.5.0760 build 20181114
[Important Notes]
- To ensure system functionality, after updating QTS to 4.3.5, please also update Container Station to 1.9 in App Center before enabling QVR Pro.
- The RADVD service previously did not have an outgoing interface. Please reconfigure the RADVD service after upgrading.
- Due to security concerns, support for "Wi-Fi ad-hoc mode" has been removed.
- This QTS update changes the file system of the system partition to ext4 for ARM-based models with Annapurna Labs processors. For data security reasons, you are not able to downgrade QTS to a previous version after this update.
Affected models: TS-131P, TS-231P, TS-431P, TS-531P, TS-231+, TS-431+, TS-231P2, TS-431P2, TS-431X, TS-431X2, TS-531X, TS-831X, TS-1231XU-RP, TS-1231XU, TS-831XU-RP, TS-831XU, TS-431XU-RP, TS-431XU, TS-431XeU, and TS-1635.
- For the status of QTS updates and maintenance for your NAS model, visit https://www.qnap.com/en/product/eol.php
- When QTS 4.3.x is installed on NAS models running on 64-bit Intel and AMD processors, some applications may not be supported. To check if installed apps on your NAS are compatible with QTS 4.3.x, download the QTS 64-bit compatibility tool and install it on your current QTS build. (https://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
- Below are the kernel versions for NAS models that are supported by QTS 4.3.5:
Kernel 3.10.20: TS-128, TS-228
Kernel 3.2.26: TS-x31, TS-x31U
Kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
Kernel 4.2.8: all other models supported by QTS 4.3.5
- Due to the limitations of future kernel updates, QTS 4.3.5 is the final available QTS update for the following NAS models: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, and TS-470.
- Due to the limitations of non-expandable memory capacity and 32-bit processor architecture, starting from QTS 4.3.5, the TS-128 and TS-228 no longer support Container Station and all the dependent applications, including Notes Station 3, Qcontactz, QcalAgent, AWS Greengrass, and QIoT Suite Lite.
[Fixed Issues]
- Users could not change the label of an external USB drive in Storage & Snapshots.
- QNAP Network Connectivity Status Indicator (NCSI) could not function normally when users accessed the Internet in China.
- No warning messages would appear when users reached the maximum number of filters in Syslog Server.
- QTS would not save changes in the NFS host access permissions after users restarted the NAS.
- Creating a scheduled snapshot replica job without specifying a date would cause high CPU usage.
- Network & Virtual Switch would display an incorrect number of ethernet ports in the back panel drawing of TS-963X.
Nuova release a distanza di pochi giorni dalla precedente, speriamo di arrivare presto e con non troppe build alle spalle, ad una buona versione:
TS-453B 4Gb
QTS on QM2 - SSD 970 EVO 500GB & Archivio WD 10TB
Re: QTS 4.3.5.0760 build 20181114
per chi non è forte in inglese, vi metto la traduzione
[Note importanti]
- Per garantire la funzionalità del sistema, dopo aver aggiornato QTS alla versione 4.3.5, aggiornare anche Container Station a 1.9 in App Center prima di abilitare QVR Pro.
- Il servizio RADVD in precedenza non disponeva di un'interfaccia in uscita. Si prega di riconfigurare il servizio RADVD dopo l'aggiornamento.
- A causa di problemi di sicurezza, il supporto per la "modalità ad-hoc Wi-Fi" è stato rimosso.
- Questo aggiornamento QTS modifica il file system della partizione di sistema in ext4 per i modelli basati su ARM con i processori di Annapurna Labs. Per motivi di sicurezza dei dati, non è possibile eseguire il downgrade di QTS a una versione precedente dopo questo aggiornamento.
Modelli interessati: TS-131P, TS-231P, TS-431P, TS-531P, TS-231 +, TS-431 +, TS-231P2, TS-431P2, TS-431X, TS-431X2, TS-531X, TS -831X, TS-1231XU-RP, TS-1231XU, TS-831XU-RP, TS-831XU, TS-431XU-RP, TS-431XU, TS-431XeU e TS-1635.
- Per lo stato degli aggiornamenti QTS e della manutenzione per il modello NAS, visitare https://www.qnap.com/en/product/eol.php
- Quando QTS 4.3.x è installato su modelli NAS in esecuzione su processori Intel e AMD a 64 bit, alcune applicazioni potrebbero non essere supportate. Per verificare se le app installate sul NAS sono compatibili con QTS 4.3.x, scaricare lo strumento di compatibilità QTS a 64 bit e installarlo nella build QTS corrente. (Https://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
- Di seguito sono riportate le versioni del kernel per i modelli NAS supportate da QTS 4.3.5:
Kernel 4.2.8: tutti gli altri modelli supportati da QTS 4.3.5
- A causa dei limiti dei futuri aggiornamenti del kernel, QTS 4.3.5 è l'ultimo aggiornamento QTS disponibile per i seguenti modelli NAS: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U- SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP , TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro e TS- 470.
- A causa delle limitazioni della capacità di memoria non espandibile e dell'architettura del processore a 32 bit, a partire da QTS 4.3.5, TS-128 e TS-228 non supportano più Container Station e tutte le applicazioni dipendenti, tra cui Notes Station 3, Qcontactz , QcalAgent, AWS Greengrass e QIoT Suite Lite.
[Risolti i problemi]
- Gli utenti non possono modificare l'etichetta di un'unità USB esterna in Archiviazione e istantanee.
- L'indicatore di stato della connettività di rete QNAP (NCSI) potrebbe non funzionare normalmente quando gli utenti accedono a Internet in Cina.
- Nessun messaggio di avviso comparirà quando gli utenti hanno raggiunto il numero massimo di filtri in Syslog Server.
- QTS non ha salvato le modifiche nelle autorizzazioni di accesso all'host NFS dopo che gli utenti hanno riavviato il NAS.
- La creazione di un lavoro di replica di un'istantanea programmata senza specificare una data causerebbe un elevato utilizzo della CPU.
- Network e Virtual Switch mostrerebbero un numero errato di porte Ethernet nel disegno del pannello posteriore di TS-963X.
Ma nessuno ha installato ancora questa versione?
TS-453B 4Gb
Io... appena è uscita... perché? Problemi?
io ho seguito FFFAB, finora non ho trovato problemi!
Anch'io, e non ho problemi.
TS 133: SGT EXOS 16TB
TS 251+: WD40EFAX (SMR!!)
Installata su x31, per ora va tutto
Chiedevo semplicemente perché nessuno aveva ancora scritto nulla dopo la segnalazione di questo FW.
TS-453B 4Gb
Nel mondo Qnap, questo comportamento del forum è da interpretare come "firmware particolarmente riuscito"
Mi sfuggiva, terrò presente per il futuro. Grazie
TS-453B 4Gb
