COME SEMPRE OCCHIO A QUELLO CHE FATE ALTRIMENTI IL NAS DIVENTA UN FERMA PORTE. IO NON MI ASSUMO NESSUNA RESPONSABILITÀ'.
DOWNLOAD
DOWNLOAD= = = = = = = = = = QNAP BIOS Release Note = = = = = = = = = =
Model : TS-X51U,TS-X53U (QW87)
SIO : F71869
Flash Method
1.BIOS Name.bat
CPU Microcode :
M0230671113 M0230671116 M0230672213 M0C30672216
M0C30673322 M0C30678815 M0230672228 M0230673322
M0230678816 M013067222D M0130673322 M0130678806
Note:
1. N/A
Known issues:
Version : QW87AR09
Build Date : 2014/12/17
CheckSum : 617FE612h
Arthur : Tom Su
-Bug Fixes
1.Fix Bug 53747: Cannot restore TPM setting via "Restore Defaults" option.
2.Fix Bug 53750: Cannot restore Intel VT setting via "Restore Defaults" option.
-Newly Implemented Items
1.Workaround for drop 9215 controller issue.
-Changes/Updates
Version : QW87AR08
Build Date : 2014/11/26
CheckSum : 6180E2A4h
Arthur : Tom Su
-Bug Fixes
1.Disable PCH SATA.
2.Enable TPM module.
3.Add usb JBOD UX-1200U and UX-800U ID to BIOS.
-Changes/Updates
Version : QW87AR07
Build Date : 2014/10/13
CheckSum : 625B01DEh
Arthur : Tom Su
-Bug Fixes
1.Choose pin function is GPIO12.
-Changes/Updates
Version : QW87AR06
Build Date : 2014/10/09
CheckSum : 625A9CFDh
Arthur : Tom Su
-Bug Fixes
1.Modify GPIO12 setting.
-Changes/Updates
Version : QW87AR05
Build Date : 2014/10/03
CheckSum : 625B7CDAh
Arthur : Tom Su
-Bug Fixes
1.Remove bug 49319 workaround.
-Changes/Updates
Version : QW87AR04
Build Date : 2014/09/26
CheckSum : 625B1981h
Arthur : Tom Su
-Bug Fixes
1.Workaround to fix Bug 49319: PowerOutage test fail.
1.Support SPI ROM "EON" EN25S64
2.Support SPI ROM "MXIC" MX25U6435E
-Changes/Updates
Version : QW87AR03
Build Date : 2014/08/19
CheckSum : 625AFBE1h
Arthur : Tom Su
-Bug Fixes
1. Fix Bug 48422 - There is Power Technology option in BIOS Setup
2. Fix Bug 48423 - System power on fail when set DVMT pre-allocated >= 416M
3. Fix Bug 48420 - There is EFI Shell option in BIOS Boot menu
4. Fix Bug 48418 - Cannot boot to DOM when USB JBOD is attached
1.Change HDD power delay setting from 5s to 8s.
-Changes/Updates
Version : QW87AR02
Build Date : 2014/07/24
CheckSum : 61B57F7Eh
Arthur : Tom Su
-Bug Fixes
1.Fix bug: Can't boot into Win7.
-Changes/Updates
Version : QW87AR01
Build Date : 2014/07/21
CheckSum : 61B5B648h
Arthur : Tom Su
-Bug Fixes
1. First Release.
-Changes/Updates
