RAID 5 non attivo.... chi mi aiuta
ateacme
Messaggio da ateacme »
Ciao a tutti stamattina ho acceso il mio qnap ts-809 configurato RAID 5 e mi appare questo messaggio
Volume non attivo ......aiutoooooooooooooooooo
admin@192.168.1.200's password:
[~] # echo "NAS Model: $(getsysinfo model)"
NAS Model: TS-809
[~] # echo "Firmware: $(getcfg system version) Build $(getcfg system 'Build N umber')"
Firmware: 4.2.6 Build 20170620
[~] # echo "System Name: $(/bin/hostname)"
System Name: QNAP
[~] # echo "NAS IP address: $(ifconfig $(getcfg network 'Default GW Device') | g rep addr: | awk '{ print $2 }' | cut -d: -f2)"
NAS IP address: 192.168.1.200
[~] # df -h
Filesystem Size Used Available Use% Mounted on
/dev/ramdisk 151.1M 132.2M 18.8M 88% /
tmpfs 64.0M 264.0k 63.7M 0% /tmp
tmpfs 999.6M 0 999.6M 0% /dev/shm
tmpfs 16.0M 0 16.0M 0% /share
/dev/sda4 371.0M 239.2M 131.8M 64% /mnt/ext
/dev/md9 509.5M 138.1M 371.3M 27% /mnt/HDA_ROOT
df: /share/external/UHCI Host Controller: Protocol error
tmpfs 1.0M 0 1.0M 0% /mnt/rf/nd
[~] # mount
/proc on /proc type proc (rw)
none on /dev/pts type devpts (rw,gid=5,mode=620)
sysfs on /sys type sysfs (rw)
tmpfs on /tmp type tmpfs (rw,size=64M)
tmpfs on /dev/shm type tmpfs (rw)
tmpfs on /share type tmpfs (rw,size=16M)
none on /proc/bus/usb type usbfs (rw)
/dev/sda4 on /mnt/ext type ext3 (rw)
/dev/md9 on /mnt/HDA_ROOT type ext3 (rw,data=ordered)
gphotofs on /share/external/UHCI Host Controller type fuse.gphotofs (rw,nosuid,n odev)
tmpfs on /mnt/rf/nd type tmpfs (rw,size=1m)
none on /sys/kernel/config type configfs (rw)
[~] # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [multipath]
md8 : active raid1 sdc2[3](S) sdb2[2] sda2[0]
530132 blocks super 1.0 [2/2] [UU]
md13 : active raid1 sda4[0] sde4[7] sdh4[6] sdg4[5] sdf4[4] sdd4[3] sdc4[2] sdb4[1]
458880 blocks [8/8] [UUUUUUUU]
bitmap: 1/57 pages [4KB], 4KB chunk
md9 : active raid1 sda1[0] sdh1[7] sdg1[6] sdf1[5] sde1[4] sdd1[3] sdc1[2] sdb1[1]
530048 blocks [8/8] [UUUUUUUU]
bitmap: 1/65 pages [4KB], 4KB chunk
unused devices: <none>
[~] # echo "QNAP Serial Number: $(/sbin/get_hwsn)"
QNAP Serial Number: null
Rayeta76
Re: RAID 5 non attivo.... chi mi aiuta
Messaggio da Rayeta76 »
ateacme ha scritto:Ciao a tutti stamattina ho acceso il mio qnap ts-809 configurato RAID 5 e mi appare questo messaggio
NAS Model: TS-809
System Name: QNAP
[~] # df -h
[~] # mount
Ticket a qnap
Enviado desde mi D6603 mediante Tapatalk
