CPU Freescale™ ARM® Cortex®-A9 dual-core 1.2GHz processor with hardware encryption engine
DRAM 512MB
Flash Memory 512MB eMMC
Hard Disk Drive 4 x 3.5" or 2.5" SATA 6Gb/s, SATA 3Gb/s HDD or SSD
NOTE:
1. The system is shipped without HDD.
2. For the HDD compatibility list, please visit http://www.qnap.com/compatibility
Hard Disk Tray 4 x Hot swappable tray
LAN Port 2 x Gigabit RJ-45 Ethernet port
LED Indicators Power, Status, LAN, USB, HDD1-4
USB/eSATA 3 x USB 3.0 port (Front: 1, Rear: 2)
1 x eSATA port (Rear)
Support USB & eSATA storage devices, USB printer, pen drive, and UPS etc.
Buttons Power, USB One-Touch-Copy, reset
Alarm Buzzer System warning
Form Factor Tower
Dimensions 177(H) x 180(W) x 235(D) mm
6.97(H) x 7.09(W) x 9.25(D) inch
Weight Net: 3 kg (6.61 lbs); Gross: 4.3 kg (9.48 lbs)
Power Consumption (W) HDD standby: 14.84W
In operation: 33.75W
(with 2TB HDDs installed)
Operating Temperature 0 - 40˚C / 32~104°F
Humidity 5 ~ 95% RH non-condensing, wet bulb: 27˚C
Power Supply External Power Adapter, 90W, 100-240V
Secure Design Kensington security slot for theft prevention
Fan 1 x quiet cooling fan (12 cm, 12V DC)
Certification FCC, CE, BSMI, VCCI, C-TICK
